Author Topic: Welding new rear quarter panel  (Read 4930 times)
Offline Chlngrcrzy
« on: December 12, 2007 - 11:17:56 AM »
I am ready to fit my new rear quarter panel on the car, and i was thinking that it would be simpler and easier to weld it on if i had Pre-drilled holes around the outside lip. Am i heading the right direction? This is the first one i have ever done and i want to make sure i get it right.
Offline farmboy70
Re: Welding new rear quarter panel
« Reply #1 on: December 12, 2007 - 11:42:13 AM »
Pre drilling the hole will make it easier, but be sure to not place the weld holes in the area of the wheel molding screws if you are going with moldings. If you have the original panel you can lay it on top of the new one to mark the original location for the welds.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: December 12, 2007 - 12:12:37 PM »
I also have found that a #3 center drill works very well since the body diameter is 1/4" and it leaves very little or a burr.
Kurt - SE Michigan
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: December 13, 2007 - 09:09:21 AM »
Like fram boy suggested predrill all the holes in the factory locations or as close to them as you can.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline farmboy70
« Reply #4 on: December 13, 2007 - 09:38:12 AM »
Fram boy, I don't even use those filters. :smilielol:
Offline 73EStroker
« Reply #5 on: December 13, 2007 - 03:04:29 PM »
Also - make sure you either use Cleco temporary rivets or (if not available) self tapping srews to hold the quarter in place whilst welding it. Ensures the best gaps between doors and trunk lid. Remove the screws or Clecos when done and fill the holes with weld.
Barry (Salmon Arm)
Offline Chlngrcrzy
« Reply #6 on: December 13, 2007 - 08:45:29 PM »
Thanks for the ideas guys. I also have to weld in the dutchman panel, so it will take a lot of fitting and checking along the way. I have a bunch of self-tapping srews left over from when i did the driver floor pan.
Offline R/T hedkace
« Reply #7 on: December 15, 2007 - 08:00:04 PM »
 :roflsmiley: :roflsmiley: :roflsmiley: :roflsmiley:
 I'm in the middle......well was in the middle of doing this myself   :clueless:  :sleeping:
The best advice I could give you is to not take any advice from me  :bricks1:
 Seriously though, there are enough folks here who really know what their doing to walk you through any issues.
 I would not have had the ba!!s to take on my project, if it wasn't for the help of many here  :cheers:
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
« Reply #8 on: December 15, 2007 - 10:37:46 PM »
I'll be getting my new quarter panel very soon. My car is on the rotisserie. Since I already welded in the sub frame connectors, I guess it really doesn't matter anymore to have it on jack stands to install. What do you think?
Offline Chlngrcrzy
« Reply #9 on: December 15, 2007 - 11:06:13 PM »
Hedkace, can you get anymore in that garage of yours. :smilielol:
Offline R/T hedkace
« Reply #10 on: December 16, 2007 - 06:30:31 AM »
Was not my garage.
My buddy was kind enough to let me use his for a while.
 Unfortunately, I could not get off my @ss enough to go up there, and make some sound progress,
so now shes back home in my garage  :bricks1:
Sometimes life doesn't always go according to plan ....... :walkaway:
Live, and learn  :cheers:
Jeff
1969 Barracuda
 Massachusetts
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #11 on: December 17, 2007 - 02:33:39 AM »
Well a new way that my husband  have been doing rear 1/4 is glueing them on using duramix.Check out the durmix website for more info alot faster easier and less chance of warped.
Offline Chlngrcrzy
« Reply #12 on: December 17, 2007 - 11:19:32 AM »
i had heard of people using durmix for putting down floor pans, but did not realize you could use it for outside body panels?
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #13 on: December 17, 2007 - 12:43:22 PM »
hope you enjoy seeing the seam thru the paint.
Offline Moparpena
    • Project Challenger r/t
« Reply #14 on: December 17, 2007 - 12:52:09 PM »
Better to weld them, I weld my own.
Dodge Challenger r/t 1970, fc7 car. Restoration link below:
http://penasgarage.blogspot.com/
