Author Topic: good 440 to build  (Read 1687 times)
Offline majik16106
good 440 to build
« on: December 13, 2007 - 11:37:28 AM »
complete, 440 out of an rv. i will try to get head casting numbers, was running when pulled. this is carb to oil pan. freshen up or turn into a monster. someone throw me a couple hundred bucks and come pick it up. located in marietta, ga. i just need it out of the garage ASAP. best way to reach me is e-mail of phone listed at bottom of this post. thanks a ton!
Paul
Majik16106@yahoo.com
770-842-4001
Offline Dusty1
  • Revived
Re: good 440 to build
« Reply #1 on: December 13, 2007 - 06:44:36 PM »
I have a 727, what transmission would have to be put with that motor?
Garys 1972 BS
« Reply #2 on: December 13, 2007 - 06:55:51 PM »
Dusty1, A big block 727 is what you need. Or a 4spd.  They did not make a 904 for a bb engine :2thumbs:  Is yours off of a 383, 361,400, 426w, 413, 426h, 440?
Offline Dusty1
  • Revived
« Reply #3 on: December 13, 2007 - 07:03:28 PM »
Unless I've been told wrong, that is what is on this '67 318. The oil pan is shaped like the 727's I've seen for sale. Does that sound right? Maybe not, mine isn't the squarest pan of the two, mine has a slant and a bulged corner. Maybe I'd need a tranny.
« Last Edit: December 13, 2007 - 07:21:56 PM by Dusty1 »
Garys 1972 BS
« Reply #4 on: December 13, 2007 - 07:25:16 PM »
They also installed 727's on small blocks, but you still need a bb bell housing patern 727. They are common to find or buy.
Offline Dusty1
  • Revived
« Reply #5 on: December 13, 2007 - 07:49:09 PM »
Thank You! Still learning.
Garys 1972 BS
Offline 1badcuda
« Reply #6 on: December 15, 2007 - 03:46:08 PM »
You might want to double check on the crank in that as well, it might not have been factory drilled for a pilot bushing for a 4 speed in which case you would have to run an auto. I bought a 440 from an RV 3 years ago and was dissapointed to find that it was going to take a crap load of work to modify it for a 4 speed,  It's not a huge problem but you do have to remove the crank and have it drilled and re-balanced and more than likely it's a cast crank, so if you are going to go through all the trouble of converting to a 4 gear, you might as well just find a steel crank to fit that rascle. Just my 2 cents from experience, Dave
Offline Dusty1
  • Revived
« Reply #7 on: December 15, 2007 - 10:27:55 PM »
Thanks Dave, good to know. There are too many details. I'm trying to talk to a guy that has a '69 Road Runner sitting outside rusting away. But it happens to have a 426 Hemi sitting in it. No problems there are there?
Garys 1972 BS
Offline 440WIP
« Reply #8 on: December 16, 2007 - 01:38:18 AM »
The only problem that I can see is that the hemi Roadrunner is not sitting in your driveway. Get on it - if you know about it - so does someone else!!!
Offline 1badcuda
« Reply #9 on: December 16, 2007 - 01:32:47 PM »
I see no problems there, A Hemi transplant is a good thing, unless it's a factory hemi runner in which case I would either fix it up and keep it or fix it up and sell it and buy a crate hemi and have some cash in your pocket or if it's to far gone pull that big son of a gun out and either sell it and buy a new crate hemi or rebuild it and stay vintage one way or another IT'S A HEMI  :woo:   Dave
Offline Dusty1
  • Revived
« Reply #10 on: December 16, 2007 - 02:56:49 PM »
The RR didn't come with the Hemi originally and I haven't seen it yet. A man I know (chevy man) is a friend to this guy and told me its been just sitting out for a long time and he has no plans to restore. I'll hopefully talk to him monday, only one way to know.
Garys 1972 BS
Offline Dusty1
  • Revived
« Reply #11 on: December 17, 2007 - 10:27:49 PM »
Hemi gone, now resides in Chattanooga, Tn. :(
Garys 1972 BS
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #12 on: December 18, 2007 - 04:16:13 PM »
majik - I have family down in that area (used to live in Augusta) - I'm very interested.  I'm not sure what is required to make this fit in my 'Cuda though.
What year is the motor?  I have no idea how I'll get it up here (I'm in PA now) but I can try to figure something out.  Let me know and I'll PM you an offer.
Jeff
Offline ViperMan
    • JS Custom Cars
« Reply #13 on: December 20, 2007 - 03:08:04 PM »
**UPDATE**
I think it's safe to say that this has been spoken for.
Jeff
My Barracuda's becomin' a 'Cuda!!!
Offline ViperMan
    • JS Custom Cars
« Reply #14 on: January 12, 2008 - 10:38:58 PM »
SOLD!!!
Thanks Paul - you're a good man!
Jeff
