BAD Challenger - twin turbo 426 Hemi stroker, tube chassis, 6 speed, etc....
Author Topic: BAD Challenger - twin turbo 426 Hemi stroker, tube chassis, 6 speed, etc....  (Read 210226 times)
Offline BacardiCBR
Re: BAD Challenger.... C5 suspension, 6.1 SRT8 Hemi, 6 speed, etc....
« Reply #180 on: June 07, 2008 - 12:21:41 PM »
KA-CHING!!!  $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
 :clapping:
'70 AAR Tribute Car
Offline IMNCARN82
  • LeDZeP
« Reply #181 on: June 07, 2008 - 08:25:03 PM »
 :droolingbounce:     Yeah nice intake. the whole thing is way over the top. :crazy: :bigsmile: :worshippy
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Bruning Auto Design
« Reply #182 on: June 11, 2008 - 01:39:46 PM »
More parts
Sparco Modena's arrived today (better pics soon)
And a picture of one of the stainless CNC machined T4 flanges (again, better pics soon)
Offline Street_Challenged73
« Reply #183 on: June 11, 2008 - 06:14:49 PM »
Sweetness!!!  I think I'm eventually going with a set of leather Sparcos to replace my worn, cloth racing seats in my soon-to-be summer driver.
Offline mopar_guy
« Reply #184 on: June 11, 2008 - 06:23:22 PM »
everything about this car is top notch,i love it! great work  :2thumbs:
« Reply #185 on: June 11, 2008 - 07:46:09 PM »
Thanks guys, the Sparco's definitely aren't the cheapest aftermarket seat option available...
The Modena is a high quality well made seat, unlike the overpriced yard furniture my wife just HAD to have. :)
They aren't too overkill either in the "tuner look" department either.  A lot of "racing" seats have huge shoulder bolsters and softball size harness holes, etc.  These are nice and trim with a similar side profile as the stock Challenger seats.
More updates soon :)
« Reply #186 on: June 30, 2008 - 04:56:42 PM »
a few updates...
ATI's 6.1 HEMI Super Damper...
With the mock-up ball bearing turbos added to the works...
Offline EvilTwinATX
« Reply #187 on: June 30, 2008 - 05:03:59 PM »
I can hear the BOV now!! What a sweet sweet ride!  :2thumbs:
« Reply #188 on: June 30, 2008 - 05:31:53 PM »
Couple more of the turbos with the ADE flanges.
Working on the headers.  Cone Engineering's header alignment tools come in handy-
« Reply #189 on: June 30, 2008 - 05:53:44 PM »
Bob from Automotive Design Engineering put his digitizing equipment to work.  The waterneck protrudes up above the intake flanges on the heads, and the design of the dual throttle body intake is very low.  Bob will input these points into the 3D drawing to check for clearance issues, etc.
Another front the front (including a shot of the custom dash)
Oil pan in the works also
Picture of the oil pan flange coming together
« Reply #190 on: June 30, 2008 - 06:17:48 PM »
Another big thanks to American Auto Wire for their support.
www.americanautowire.com
We are using their Highway 22 modular wiring harness kit and trunk mounted battery kit.
The HWY 22 kit includes:
-2 power circuits supported through 15 fuses and 1 circuit breaker
-Battery and accessory  power tap studs provided for system expansion
-Panel protected with a 175 amp Mega-Fuse junction block with a 8 gauge panel feed wire
-Nylon mechanically secured panel containing secondary push-back locks, has a 7-1/2” x 4-1/2” footprint, 3-3/8” in height, and mounted on a (G10) non-conductive epoxy base
-All power buss bars are constructed of 6 gauge copper
-All wires are constructed from heat resistant (-60F- +275F)
-GXL heavy-wall wire with laser printed circuit identification every 2 inches
-Color coded wires for ease of installation
-All power circuits wires are 12 gauge constructed
-New front loaded vibration proof self- locking (Hooke’s Law) screw down terminal connection
-Dedicated battery and ignition circuits for electronic fuel injection (EFI) Kit contains 3 relays (Horn, Turn Signal & 40 amp Electric Fan or Fuel Pump)
-Turn signal and hazard flasher circuits provided
-8 gauge alternator feed wire provided
-The kit is set-up for a GM “SI” internally regulated alternator or GM 1-wire
-Alternator diode is also provided
-Kit includes 3 (In-dash Ignition, Headlight & Alum. Knob and Floor Dimmer) switches
-GM in-column ignition switch connectors provided, along with 3-7/8” GM steering column connectors with male and female terminals
-Plugs directly most 69-74 GM column and most aftermarket steering columns or use the terminals and connector provided to mate to any column
-Spare circuits available (for power windows, locks, cruise, etc.).
-Engine compartment (oil pressure, water temp, tach, starter, neutral safety, brake switch, ignition switch, distributor (GM HEI or Points), coil, main power and alternator)
-Chassis wiring (fuel pump, electric fan, headlights, running lights, brake lights, 3rd brake lt., directional, license plate, radio, heat & AC, and wipers)
-Full color schematic of overall vehicle wiring along with individual harness subkit instructions for trouble-free installation.
Another with the trunk mount battery kit
« Reply #191 on: June 30, 2008 - 07:45:02 PM »
Couple more header "in process" pics.
A shot of the merge collector bullets that are included in Cone Engineering's collector kits.  Cone will also pre-weld the bullets for a nominal fee.
Before (Individual vanes with provided assembly tool)
After
Offline ntstlgl1970
  • T a c o c a t
« Reply #192 on: June 30, 2008 - 07:50:06 PM »
It's hard to tell from the pictures but are the pipes that close to to the valve cover? Just wondering
« Reply #193 on: June 30, 2008 - 08:23:22 PM »
There is an inch of clearance at the bottom of the valve cover (widest point of the block), but the space limitations are tight for sure.
The stock valve covers will be replaced by a set of aluminum covers that are in the works.  Additional provisions will be made to help with heat as well (functional R/T hood scoops, etc).
Offline EvilTwinATX
« Reply #194 on: June 30, 2008 - 09:16:16 PM »
tj40ounce... I have built some custom door strikers for e-bodies. They are really nice.. why don't you buy a set and put that on that beautiful challenger?! They would look so sweet!
