Author Topic: BAD Challenger - twin turbo 426 Hemi stroker, tube chassis, 6 speed, etc....  (Read 210222 times)
Offline MoparCar
Re: BAD Challenger.... C5 suspension, 6.1 SRT8 Hemi, 6 speed, etc....
« Reply #195 on: June 30, 2008 - 11:20:35 PM »
You and your shop's work continue to amaze me!!! Wow. Thanks for the update.
Wes
Offline Bruning Auto Design
« Reply #196 on: July 10, 2008 - 06:11:12 PM »
Updates - KRC Aluminum Pump w/serpentine pulley & 4" crank pulley
Crank pulley after some machine time....
front
back -
Ready for Tim's crankshaft adapter...
« Reply #197 on: July 10, 2008 - 06:34:55 PM »
Crank shaft adapter sequence
Mounting holes drilled/tapped on the rotary table after OD turned to correct diameter
Machining correct ID
Pulley and adapter assembled onto the backside of the ATI hub
« Reply #198 on: July 10, 2008 - 06:46:03 PM »
Back on the engine with the ATI Super Damper in place...
Yes, there's clearance.  :)
With the steering rack in
One more - the 12 point bolts will be changed to a low head cap screw.
Offline ntstlgl1970
  • T a c o c a t
« Reply #199 on: July 10, 2008 - 07:30:38 PM »
Is this a customer's car or a "showcase" kind of car to show what you guys can do?
or both?
either way it's an awesome car...
« Reply #200 on: July 10, 2008 - 07:54:16 PM »
or both?
thanks,
It's a shop car er... I mean, my dad's car :)
Offline Street_Challenged73
« Reply #201 on: July 10, 2008 - 11:41:42 PM »
That's going to be such an animal when it's finished!!!  The TT's on my V-6 get it moving quickly and there probably 1/3 the size, if not smaller.
Offline Stacked440
« Reply #202 on: July 11, 2008 - 01:35:37 AM »
Bad Challenger is a HUGE understatement...that thing is the beastiest challenger I have ever seen...anywhere.  Herman Munster would run from that monster :thumbsup:
-Kyle-
Offline 808cuda
  • RARE Fish!
« Reply #203 on: July 11, 2008 - 03:34:35 AM »
This post never ceases to amaze me!
What is the PSI rating of that KRC pump?
1970 N96 Cuda 340 4speed (now Keisler 5 speed)
« Reply #204 on: July 14, 2008 - 02:25:00 PM »
It is a 7.2cc pump that uses -6 changeable control valves (9 optional sizes) with a max speed of 9,000 RPM.  The pump also comes with the standard 1080 psi relieve spool, which should work well with the 2.62 pinion ratio and medium valved servo on the Woodward rack.  A 1450 psi relief is also available, but not necessary since the steering arms on the C5 spindles are a decent length.  Also, the current valve flows 2.11 GPM.  We can switch to a different size to reduce assist, increase feel, etc.
Long story short, the KRC pump can be fine tuned for our application.  The pulley can be easily removed as well, since it uses a 17 spline hub instead of the standard pressed-on style pulley.
Got back late last night from the Columbus Goodguys show - what a great time.  One of my favorites is a twin-procharged 6.1 HEMI Cuda.  I think it should have made the top five for street machine of the year, but what do I know....  :)
Congrats to Mike & Jim Ring for another job well done!  They definitely outdid themselves with another beautiful build.
Offline go-fish
« Reply #205 on: July 16, 2008 - 06:22:49 AM »
Is there any info on this twin 'charged 'cuda? I would like to see this. Wonder if PHR will show anything on it.
« Reply #206 on: July 17, 2008 - 02:58:56 PM »
check out page 3 - owned by Glen Baugus.  Very nice car
http://garagescene.net/gallery2/main.php?g2_itemId=45&g2_page=3
« Reply #207 on: July 17, 2008 - 02:59:33 PM »
Thanks to Liz & the crew at Popular Hot Rodding for including the Challenger in September's "under construction" section.
No Tim Haden's here, but the pictures, Jason's rendering, text, etc. look great.
Offline IMNCARN82
  • LeDZeP
« Reply #208 on: July 17, 2008 - 05:57:34 PM »
I have seen some amazing vehicles. This is the sickest Challenger I've ever seen. Thanks for sharing!! :2thumbs:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline go-fish
« Reply #209 on: July 18, 2008 - 08:58:52 AM »
The car looks good. There are many things that make the car very nice but,..... the smooth tail panel?
Very nice car indeed though.
I love the smooth glass look!
« Last Edit: July 18, 2008 - 09:04:51 AM by go-fish »
