An upgrade for the stock 6.1 HEMI arrived earlier this week - a 426 C.I.D HEMI stroker short block (based on the new generation SRT-8) from
Plum Floored Creations - Your source for New Hemi Swapswww.plumfloored.comEngine specs-
-426 Machined 6.1 Liter Block, 4.090 Bore, Billet Main Caps, Line honed, Internally balanced, New forging Crank (4.050 X 2.100) , Aftermarket H-Beam Rods (6.125 X .927), Rings, Bearings, ARP Main/Head Studs, Mahle Coated Dish Pistons (8.8 to 1), and Cometic head gaskets.
- Aluminum "Factory Fresh" head castings, 5-Axis CNC-ported , "Beehive" competition valve springs, One-piece stainless steel 2.055" Intake and 1.600" Exhaust Valves, Titanium 7° Valve Spring Retainers, Machined 7° round groove valve locks, High-Temperature Viton® valve seals, Bronze alloy valve guides and hardened, custom valve seats, Premium "5-angle" CNC-machined valve job, new rockers & shafts, competition push rods, new lifters, timing chain.
-Power Ported Performance Custom Grind Turbo Camshaft.
-Expected output 700-800 horsepower
The heads and camshaft should arrive later this week.
