BAD Challenger - twin turbo 426 Hemi stroker, tube chassis, 6 speed, etc....
Author Topic: BAD Challenger - twin turbo 426 Hemi stroker, tube chassis, 6 speed, etc....  (Read 210223 times)
Offline MoparCar
Re: BAD Challenger.... C5 suspension, 6.1 SRT8 Hemi, 6 speed, etc....
« Reply #225 on: August 04, 2008 - 11:20:51 PM »
Wow!!!!!!  :jumping: I can't believe the detail to this build. You guys are amazing! Keep it up!
If I could afford it, I'd just dump my car at your shop and tell you do your thing. But you inspire the rest of us. I'm really looking forward to the products for the 3G Hemi you're working on with various manufacturers. We need all of it!
Great stuff!
Wes
Offline 472 R/T SE
« Reply #226 on: August 14, 2008 - 10:55:37 PM »
Quite simply the BADDEST Challenger on earth.   :thumbsup:
And to think this is being done here local.  Hopefully that means I get to see it.  :drool:
HELP SUPPORT THE REGISTRIES because all cars matter.
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Offline Bruning Auto Design
« Reply #227 on: August 22, 2008 - 08:11:07 PM »
Quick update - received some of the ADE intake parts from the machine shop
throttle body mounting plate
With the throttle body's mocked up
Also, more turbo plumbing.  Waiting on a 1 5/8" mandrel bends to plumb the Tial wastegates from Guy at www.rockfordracecraft.com
« Reply #228 on: September 24, 2008 - 05:36:31 PM »
Update - Intake fabrication underway
« Reply #229 on: September 24, 2008 - 05:54:54 PM »
An upgrade for the stock 6.1 HEMI arrived earlier this week - a 426 C.I.D HEMI stroker short block (based on the new generation SRT-8) from Plum Floored Creations - Your source for New Hemi Swaps
www.plumfloored.com
Engine specs-
-426 Machined 6.1 Liter Block, 4.090 Bore, Billet Main Caps, Line honed,  Internally balanced, New forging Crank (4.050 X 2.100) , Aftermarket H-Beam Rods (6.125 X .927), Rings, Bearings, ARP Main/Head Studs, Mahle Coated Dish Pistons (8.8 to 1), and Cometic head gaskets.
- Aluminum "Factory Fresh" head castings, 5-Axis CNC-ported , "Beehive" competition valve springs, One-piece stainless steel 2.055" Intake and 1.600" Exhaust Valves, Titanium 7° Valve Spring Retainers, Machined 7° round groove valve locks, High-Temperature Viton® valve seals, Bronze alloy valve guides and hardened, custom valve seats, Premium "5-angle" CNC-machined valve job, new rockers & shafts, competition push rods, new lifters, timing chain.
-Power Ported Performance Custom Grind Turbo Camshaft.
-Expected output 700-800 horsepower
The heads and camshaft should arrive later this week.
« Reply #230 on: September 24, 2008 - 06:24:05 PM »
WOWSA!!    :wow:    :clapping:   :woo:   :woohoo:
« Reply #231 on: September 25, 2008 - 04:41:11 PM »
Received the A/C compressor from Hot Rod Air - Sanden SD7176 with a polished finish.
www.hotrodair.com
Offline black71
  • eph 6:12
« Reply #232 on: September 29, 2008 - 08:41:01 PM »
first off WOW! wish i could do a build like that! sencondly this may be a stupid question, but why corvette stuff and not viper or such? not criticising at all just curious....but man again WOW!
Offline HP2
« Reply #233 on: September 30, 2008 - 07:07:03 AM »
Corvette stuff is much easier to acquire and has more aftermarket support.
Offline black71
  • eph 6:12
« Reply #234 on: September 30, 2008 - 06:48:08 PM »
sounds like a good reason!  :bigsmile:
« Reply #235 on: October 01, 2008 - 12:07:41 PM »
There were a few reasons we went with Corvette components.  Availability and aftermarket support definitely ranked high on the list.  Tim has worked with Corvette suspension components on past projects and he wanted to utilize the rear-mounted Tremec T-56 six speed transmission and Getrag IRS differential.
There is a GM name plate on the German made differential, but none of the suspension arms, uprights, etc were made by GM if that makes any difference...  :)
« Reply #236 on: October 01, 2008 - 12:08:13 PM »
Check out the 5 page Challenger feature in the November issue of Super Rod magazine!
www.superrod.com
PDF version of the article
http://www.superrod.com/Media/PublicationsArticle/SR_0811_70Challenger_2.pdf
Offline Street_Challenged73
« Reply #237 on: October 01, 2008 - 06:19:49 PM »
Very cool!!!  Congrats on making it into that magazine!! :cheers:
« Reply #238 on: October 06, 2008 - 08:24:35 PM »
Few updates-
Received a set of 8 - 71lb/hour low impedance peak & hold fuel injectors from RC Engineering.  Very nice parts and their tech support department is top notch.
www.rceng.com
Also, the guys at Revolution Industries did an awesome job building www.bruningautodesign.com and www.etikitchallenger.com .  Still have a few things to tune up and finish, but Adam and Ian did a great job.
« Reply #239 on: October 06, 2008 - 08:39:51 PM »
Finished up a couple loose ends with the turbo and wastegate plumbing.
First set of pictures show some of the steps involved in machining a set of one-off 6-bolt stainless flanges.
Male & Female halves
Tim Machining the champfer
Drilled, tapped, and counterbored on the rotary table
Assembled - the black socket cap screws will be replaced with ARP stainless fasteners
