Author Topic: question about my ralley gauges  (Read 2780 times)
Offline cudadave72
  • you motorboatin sob!!!
« on: December 16, 2007 - 08:13:18 PM »
I was looking around for restoration wood grain pieces for my ralley gauges and noticed something strange. My 72 gauge cluster does not have the hole on the very right hand side of the panel for what I assume is a seat belt light?! All the reproduction pieces listed for a 72-74 show the hole already cut out. I know that the first assumtion is that a previous owner installed a 70-71 ralley gauge clusted in my 72 however the 70-71 has the trip odometer and clock reset knobs coming throught the face of the panel whereas mine has the correct reset knobs coming through the gauges themselves. Do I possibly have a early 72 model and if so where do I find the correct wood grain repo pieces?
Thanks
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline Katfish
  • 70 Challenger
Re: question about my ralley gauges
« Reply #1 on: December 16, 2007 - 09:30:53 PM »
I'd like to know also, I have the seat belt warning hole, but would like to get rid of it.
Offline cudadave72
« Reply #2 on: December 16, 2007 - 09:33:38 PM »
And yours is a 70??? Are your gauges original to the car?
« Last Edit: December 16, 2007 - 09:39:44 PM by 72cuda416 »
Offline Katfish
  • 70 Challenger
« Reply #3 on: December 16, 2007 - 10:38:59 PM »
Not original, I have the 72-74 style.
« Reply #4 on: December 17, 2007 - 05:33:18 AM »
the repro decal may have been installed without removing the woodgrain over the hole fo rthe seatbelt light or you could have a 71 cluster or early 72 that was never opened up ffor the seatbelt light , or possibly 73-74 only had the light
Offline cudadave72
« Reply #5 on: January 13, 2008 - 09:22:21 PM »
Thanks for the replies! The issue is that the bezel appears to be original to the car and I would like to avoid redoing it with the seatbelt light if at all possible.
Thks
Offline Jules The Wiperman
    • Jules DAddio
« Reply #6 on: January 19, 2008 - 08:57:40 AM »
On some early 72 cars you will not have the seatbelt warning light.If you want to install a repro part you will have to settle for the hole as they do not make the early type. Probably not much demand. You may want to choose to apply a wood grain overlay in which case you would have to contact DMT and ask Jim to prepare you a wood grain with no hole for the seatbelt light. He'll do it for you.
Jules
http://detroitmuscletechnologies.com/
Offline cudadave72
« Reply #7 on: January 28, 2008 - 07:30:10 PM »
Jules
I finally ran my fender tag and indeed my Cuda is an early 72 that was produced on 11/05/71 which explains the absents of the seat belt light. I found the TSB that stated the warning light was not effective untill January 72. This also helps confirm that this is original to my car.
« Last Edit: January 28, 2008 - 07:32:00 PM by 72cuda416 »
Offline cudadave72
« Reply #8 on: January 28, 2008 - 07:34:39 PM »
Also I'll mention the only noticeable damage is a couple of scratches to the left of the panel which is visable in the pictures above. Anyone ever touched one up. Suggestions???
Offline JayBee
« Reply #9 on: January 28, 2008 - 08:23:07 PM »
Never actually touched one up but those re-pop metal overlays sure look good.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #10 on: January 29, 2008 - 04:34:31 AM »
I bought  a set of those. They do look good, but aren't so cheap.
Offline miketyler
    • www.miketyler.net
« Reply #11 on: January 29, 2008 - 07:23:09 AM »
My 72 didnt have the seatbelt inidicator either. I never liked the mismatched woodgrain panels and the scratches; I used the decal and am pretty happy with it for the most part.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Katfish
  • 70 Challenger
« Reply #12 on: January 29, 2008 - 05:24:59 PM »
How hard was it to put on?  I'm a little leary after putting a decal on my original.  Boy was that a mistake, stupid thing bubbled after a yr.
« Reply #13 on: January 29, 2008 - 06:05:52 PM »
Been there, done that.  :pullinghair: The decal was my first choice because it was cheap enough, but in the bend areas it bubbled up on me.
These metal re-pops come in a flat sheet, but it's fairly simple to mold them to your plastic bezel. You do need to remove your old metal face plate first. I just used some general adhesive and a couple of clamps to hold it on overnight.
Offline miketyler
    • www.miketyler.net
« Reply #14 on: January 29, 2008 - 07:56:00 PM »
thats the first I have heard of that; mine has been on for at least a year but I stripped my panel down to the metal. Also, decal was made from a pretty good grade adhesive material. I will confess however, the turn signal insets looked ok at first but never would stay stuck down. Recently I tried applying contact cement glue and resetting them and the material didnt like the glue I used.  :faint:
72' Cuda restomod
70 Mustang Mach 1
