Author Topic: cracks in frame rails  (Read 4322 times)
Offline dutch
« on: December 17, 2007 - 02:55:41 PM »
hi there,
last weekend I put my 1970 cuda in the rotisserie and when I turned it over I found cracks in the front frame rails. The cracks are located where the rear bolts of the k-member are. As far as I can see everything is still in place and the body hasn`t bent. The doors and fenders are still on the car.I cannot find any traces of accidents but the k-member has some dents and scratches. Maybe someone seriously miscalculated a hole in the road?... Have any of you seen this before? Is this probably due to abuse, or is it metalfatique?
*** Bart ***
Re: cracks in frame rails
« Reply #1 on: December 18, 2007 - 02:25:13 AM »
it could be rust inside the rails weakening  the frame to the point where the frame has split relatively easily , you may have to cap or replace the rails , check it carefully for thickness & rust
Offline dutch
« Reply #2 on: December 18, 2007 - 08:02:58 AM »
...no rust in and out...not even a tiny spot...
the k-member bolt were pretty loose though, and on the surface where the member touches the rails the metal is polished... :clueless:
maybe this could be the reason for cracking? I can weld the cracks well, esp. now the car is op side down, but I wanted to check if this is a common problem on these cars before doing so...
*** Bart ***
Offline moparclown
« Reply #3 on: December 18, 2007 - 05:46:25 PM »
I have seen this a couple of times now,Kinda spider web cracks?Just a pointer,before you weld those cracks up.At the end of each crack,drill a small hole and then weld them up.
Offline dutch
« Reply #4 on: December 19, 2007 - 04:50:53 AM »
jeb...spiderweb...
I will spray with contrast fluid first, so I can see where the cracks really stop, then drill holes and weld.
@ moparclown;  since you have seen more cars with this problem, have you also had a chance to what happened after welding over a longer period of time?
thanks for your reply
*** Bart ***
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #5 on: December 19, 2007 - 06:07:11 AM »
hi there,
I see them all the time. Definately stress cracks. Not sure what causes them, but I just weld and blend the area off. Very common.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline ragtopdodge
« Reply #6 on: December 19, 2007 - 10:20:44 AM »
Pics?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline farmboy70
« Reply #8 on: December 19, 2007 - 02:37:35 PM »
As said before drill a small hole at the end of the crack and weld them up. Should end any more problems. If the K frame was a little loose it probably caused the cracks.
Offline 71bigblock
    • Steve's Mopars
« Reply #9 on: December 19, 2007 - 06:13:49 PM »
Ok I'll bite.  Why drill the hole?   :dunno:
To assure it wont come back I assume.   :clueless:
Offline bb71challenger
« Reply #10 on: December 19, 2007 - 06:27:01 PM »
Exactly, the hole stops the crack from spreading any further.
*Brett*
Offline moparclown
« Reply #11 on: December 19, 2007 - 06:35:10 PM »
Most of my crack background :crazy:came when I worked on snow grooming machines(snow cats)and when you welded it up without drilling that relief hole,it would come right back.As far as for any time check on frame rails,I never doubted my fix and haven't had any comebacks :cooldancing:I hope this helps
        The Clown
Offline dutch
« Reply #12 on: December 20, 2007 - 02:51:39 AM »
thank you all, I`ll start working on it this weekend. :wave:
*** Bart ***
Offline miketyler
    • www.miketyler.net
« Reply #13 on: December 20, 2007 - 06:47:16 AM »
stop drilling cracks is common sheet metal practice in aviation. Stop drilling at the both ends releives stresses local that would allow the crack to continue. However, I have seen cracks continue past stop drills.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline hemiken
« Reply #14 on: December 20, 2007 - 09:34:23 AM »
Hi Dutch,
Can you download a picture of the area that is cracked please. :2thumbs:
