Author Topic: Frame bracket location?  (Read 2152 times)
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« on: December 20, 2007 - 05:41:40 PM »
Hey all, need to weld in my Z-bar bracket, and was wondering if this looked right.  I don't want to have to cut it out later.   :grinno:
Any pictures of your own install?
Also, couple questions:
Are the two ball stud thingies equal length, or is there a short and a long one?  I vaguely remember that my '68 Charger had a long and a short one, and I think if I put a short one on the scattershield side it might bring the clutch rod a little more towards the center of the hole.
Is my Z-bar on right, or it is backwards?  I had a '68 Valiant, and I think the retainer clip was on the frame side.  Also, the end of the Z-bar covered by the e-brake cable in the picture has a bunch of holes that I assume is for ignition, column, or clutch lockout stuff.
I'm putting this thing together finally after letting it sit for a couple years, it's funny how parts get re-arranged or lost...   :-[
Thanks a TON!!!   Might be driving this thing soon!!!     :burnout: :biggrin:
« Last Edit: December 20, 2007 - 05:49:13 PM by RabidScott »
1970 Dodge Challenger
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
Re: Frame bracket location?
« Reply #1 on: December 21, 2007 - 12:52:57 AM »
the positioning looks very close , the Z bar is in upside down though , the large lever is the bottom one
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #2 on: December 21, 2007 - 04:26:23 AM »
Thanks for the info on the Z-bar CP.   :thumbsup:
I looked at pictures on another post, and it's welded on now.  I can't wait to be banging gears!!
WaywardGarage.com
« Reply #3 on: December 21, 2007 - 04:40:31 AM »
 :2thumbs:
Offline IMNCARN82
  • LeDZeP
« Reply #4 on: December 22, 2007 - 10:01:18 AM »
Just a precaution... Mine split at the ball stud nut. I put a large washer on either side. It almost tore off.And led to a glazed clutch disc before I found it :bricks1:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
