Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Torq Thrust II's on an Ebody?
« previous
next »
Print
Pages:
1
2
Author
Topic: Torq Thrust II's on an Ebody? (Read 4663 times)
moparniac
Guest
Re: Torq Thrust II's on an Ebody?
Reply #15 on:
December 22, 2007 - 07:39:03 PM »
1/2 minumum
Logged
Katfish
Resident
70 Challenger
Reply #16 on:
December 22, 2007 - 08:44:49 PM »
I'm shooting for 1/2" clearance on mine. But I've read many times this is only needed for the smaller rim sizes, 14 or 15". With the larger diameter rims, there is much less sidewall to flex.
With an 18" rim I've heard 1/4" is plenty.
Last Edit: December 23, 2007 - 03:25:37 AM by Katfish
Logged
GoodysGotaCuda
Sr. Resident
Reply #17 on:
December 24, 2007 - 12:34:38 PM »
here are my clearances with my setup. 18x9, 6"bs, 295/45/zr18, stock spring location
First one the angles arent quite perfect, figure about 3/4"
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
miketyler
Resident
Reply #18 on:
December 24, 2007 - 12:54:44 PM »
Cool, thanks. I measure 6" BS and 5 3/4" FS. For the width tire I want to run and to maintain at least .5 inch clearance will probably need to use the 1" relocation kit. That page is pretty slick and I should be able to plug in my final values and determine the largest tire I can run. Chances are, the TT2 is going to be a custom offset becuase I dont see the 6 3/8 BS working with the tire sidewall clearance.
How about height? What is generally considered safe for stock springs and fender wells? 26"?
Logged
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
