Author Topic: power steering fluid?  (Read 4149 times)
Offline burrpenick
« on: December 22, 2007 - 10:03:00 PM »
What should I use in my '72 Cuda?
GEORGE
currently Moparless
Re: power steering fluid?
« Reply #1 on: December 23, 2007 - 12:07:31 AM »
I would use Power steering fluid
Offline hemiken
« Reply #2 on: December 23, 2007 - 04:56:39 AM »
 :iagree: i would use power steering fluid aswell. :faint:
I would most deffinetly steer clear of Top Shelf drinking fluids :drunk: It could get real messy, even before the power steer bottle got opened. :puke:
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: December 23, 2007 - 05:19:17 AM »
I use Dexron 3, as in my aut.tranny...
« Reply #4 on: December 23, 2007 - 05:26:56 AM »
There is more than one type of power steering fluid?   :dunno:
« Reply #5 on: December 23, 2007 - 12:14:21 PM »
not that I have seen , , ATf will work also
Offline LAA66
« Reply #6 on: December 23, 2007 - 12:20:34 PM »
 I used ATF once and the seals started leaking.  :drool: It's a 37 year old steering box though. :2cents:
« Reply #7 on: December 23, 2007 - 01:00:56 PM »
Well, there is synthetic and conventional, so I guess there are two types of steering fluid. Since it is a hydraulic system, you could also use jack oil or brake fluid in there as well. Although they may be detrimental to its longevity and performance.
I have used atf for brake fluid before to get a broken 4x4 off a mountain and into civilization. It attacked all the rubber in the system and it required new master and wheel cylinders sometime later to restore adequate safety.
Offline FY1Cuda
« Reply #8 on: December 23, 2007 - 08:06:45 PM »
Our auto parts store sells one that is specifically for old Mopars.  It is a Sta-Lube (CRC) product and the label says it is for pre-89 Dodge, Plymouth, and Chrysler.  The counter man thought it was a little thicker than the regular Sta-Lube one.
