Author Topic: CAI Or Similar?  (Read 3032 times)
Offline Carlwalski
CAI Or Similar?
« on: December 22, 2007 - 10:20:12 PM »
This is a dumb question but is there something out there that increases air flow dramatically like a CAI? If heard Dad's SRT8 and recently put one in my Jeep and the sound inside the car is drastically improved. Just sounds awesome, plus it has better response and better performance, albeit 5-10hp.
I'm sure the factory air cleaner is very restricting, yes? no? I'm guessing the only "CAI" available for our cars is by removing the factory air cleaner (like Lucy has) and putting a bigger air filter on with just a top lid (like Dad's Cuda, 2nd photo)? If that is the only way, was sound inside the car increased?
Thanks, hope that made sense.  :lol2:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Oldschool
  • Member Since 9-05-06
Re: CAI Or Similar?
« Reply #1 on: December 22, 2007 - 10:25:10 PM »
Carl,
Back in the day, we used to take the lid off and flip it over on the stock unit.  Might need a longer carb center stud, but maybe not.  Try it and see.  If it is flippable, it will leave about an inch to an inch and a half open space all the way around the filter housing.  Sounds awesome, allows more air flow, the air remains filtered, and you keep all the stock components.  To put it back 100% stock, just flip the lid back over......     :2thumbs:
« Last Edit: December 22, 2007 - 10:26:54 PM by Oldschool »
Ken  --  In Georgia
Offline Carlwalski
Re: CAI Or Similar?
« Reply #2 on: December 22, 2007 - 10:41:07 PM »
Thanks Oldschool, now, I'm a little confused, which part am I flipping? lol
Filter, air cleaner housing or something else? Sorry, I'm half drunk and not up to play lol.  :P
Offline Oldschool
Re: CAI Or Similar?
« Reply #3 on: December 22, 2007 - 10:43:59 PM »
Just remove the stock filter housing lid and flip it over, re-install it upside down.  Try it, you'll like it....     :2thumbs:
Ken  --  In Georgia
Offline Carlwalski
Re: CAI Or Similar?
« Reply #4 on: December 22, 2007 - 11:19:08 PM »
Duh, I gotcha...I will, thanks for that. I'm guessing it's safe to do?  :cheers:
Re: CAI Or Similar?
« Reply #5 on: December 23, 2007 - 12:29:30 AM »
Check for hood clearance, also make sure tha block off plates are removed from the hood scoops
Offline Carlwalski
Re: CAI Or Similar?
« Reply #6 on: December 23, 2007 - 01:09:21 AM »
Block off plates? Wouldn't that just send all kinds of dust and junk into the engine bay?
It'd be a mess within the first hundred miles would it not. :clueless:
Thanks.  :2thumbs:
Offline Aussie Challenger
Re: CAI Or Similar?
« Reply #7 on: December 23, 2007 - 05:01:17 AM »
  Flipping the top air cleaner lid makes a great sound,    :burnout:   however I am not a fan as it allows hot under hood air into the motor. I would prefer the cooler air from outside, more dense, more H.P.  It is an old trick that many did in the 60's & 70's so it sounded better inside the cabin area.   :2thumbs:
Re: CAI Or Similar?
« Reply #8 on: December 23, 2007 - 05:42:15 AM »
Thanks.  :2thumbs:
Carl,
   What do you think I go thru with my hood scoop?   :lol:  As was suggested, flipping over the air-cleaner lid will give you more air-flow. I would suggest turning it back over at a car show though, because it looks a little stupid upside down.  :grinyes: I've been told forcing the cooler outside air into your carb is like getting free horsepower.
« Last Edit: December 23, 2007 - 07:23:13 AM by MEK-Dangerfield »
nivvy
Re: CAI Or Similar?
« Reply #9 on: December 23, 2007 - 07:31:43 AM »
Why not just take off that assembly and put on a more modern setup / K&N rather than flipping it upside down...  :2cents:
Re: CAI Or Similar?
« Reply #10 on: December 23, 2007 - 07:45:12 AM »
I've got the K&N assembly, but I think Carl would prefer to stay with the stock look.
Re: CAI Or Similar?
« Reply #11 on: December 23, 2007 - 07:47:35 AM »
   Yea flipping the lid looks bad & will ruin the finish on the topside eventually... don't ask me how I know... I get the same effect with the open element box off a '68 383 a friend gave me, new chrome units avail from MP. We used to call it the sound of a thousand alternate lifestyle males sucking at once.
nivvy
Re: CAI Or Similar?
« Reply #12 on: December 23, 2007 - 07:48:49 AM »
I figured that MEK but I would rather pop my hood at a car show with a K&N setup than some upside down flux capacitor  setup :stirpot:
Re: CAI Or Similar?
« Reply #13 on: December 23, 2007 - 07:50:21 AM »
   :smilielol:
Offline Carlwalski
Re: CAI Or Similar?
« Reply #14 on: December 23, 2007 - 09:21:46 AM »
Thanks guys, I may do some research on some set ups. I'm after better sound inside the car and a little more hp without "ruining" the stock image. I think doing what you have Mike is fine as it's something they would have done back in the day, "nostalgia correct" is something I like to do and don't mind doing if not, then stock is preferred for Lucy anyhow. Ps: Mike, got any photos of your system on and any part #'s? Also, will the system on Dad's Cuda engine above in my first post make a dramatic change in interior noise?
Thanks everyone.  :cheers:
« Last Edit: December 23, 2007 - 09:23:28 AM by Carlwalski »
