Author Topic: TRYING TO MAKE SOME PROGRESS!  (Read 20321 times)
Offline farmboy70
Re: TRYING TO MAKE SOME PROGRESS!
« Reply #90 on: July 29, 2008 - 08:55:22 AM »
Here are some pictures of when I did mine. I used a large bolt with a metal plate to pull the floor closer for welding. Give it a shot and it might help.
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #91 on: July 29, 2008 - 05:45:10 PM »
Hey Dave was that hole in the floor or did you drill it? :clueless:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline farmboy70
« Reply #92 on: July 29, 2008 - 05:47:29 PM »
I drilled a 1/2 hole there for the bolt and will put a rust proofing plug there before the carpet go's in.
« Reply #93 on: July 29, 2008 - 06:55:57 PM »
The hole in the middle of the frame lined right up with a hole on the floor board on mine.
Basically I did the same thing and pulled it in with the center bolt and nut then welded it in all around.
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #94 on: August 02, 2008 - 11:47:10 PM »
GOOD GOD MAN - not much car left there!! :22yikes:
And I thought skinning two quarters and a (single) floor pan was a lot to do!!!  :pullinghair:
Lucky you are so adept at metalwork - it would take a mere mortal years to do this!! :scared:
Offline Chlngrcrzy
« Reply #95 on: August 03, 2008 - 03:35:06 PM »
Get it all figured out and perfected, because i am approaching that time that i will be doing mine. :2thumbs:
Offline Carlwalski
« Reply #96 on: August 10, 2008 - 03:17:02 PM »
Are XV aware of just how off the fit is? Someone should tell them so they can correct the problem as they are not as described. Bugger too, I have some ready to go on for Madeline. My poor body man LOL.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #97 on: August 10, 2008 - 05:00:21 PM »
I betcha XV just copied US Cartools frame connectors. Or made some deal with them. So either one won't be an exact fit.
Offline CHUCKS71
« Reply #98 on: August 10, 2008 - 05:34:22 PM »
My friend and I are going to make new frame connectors. We are going to start by forming up some sheet metal to the size of the connectors and I will cut and grind to fit them to the floor then we will flatten them out and scan them.We will use his Mazak Lazer to cut the new pieces then we will form them up.If it work like we think the should be a nice fit.
Offline CHUCKS71
« Reply #99 on: August 10, 2008 - 06:44:29 PM »
It was nice to meet you Rob and everyone else at the Nat's.After I get the piece's formed up for the back lip of the trunk lid I can send you one if you want one.They will be .520x.700 and 57" long it should be perfect to fix the lip.
Offline ShelbyDogg
« Reply #100 on: August 10, 2008 - 09:49:46 PM »
Nice meeting you too Chuck, Thanks for the trunk lid.    I was able to return my rear floors and trade them for the correct AMD 71-74 Challenger floors. I won't have to do any custom fabricating like you did to your brand new pans.  I kept looking at their complete rear rails trying to decide if I wanted to charge another $345 for it, but decided to repair mine (I'm cheap and now a little deeper in the hole)
My friend hauled all of my parts back for me but I won't see him till Wed. After that, I should be able to get going on my vert again.
Offline drewcrane
« Reply #101 on: August 28, 2008 - 03:10:17 PM »
i installed these xv units in a day, so yea a little adjusting as cars are not the same,but they fit good after that , i used a sharpie to follow /trace the floor , and ground them to fit each side took about an hour or so , and then i welded them in, primered, undercoated and i was done by the end of the day!!!!
Offline ShelbyDogg
« Reply #102 on: August 28, 2008 - 05:41:18 PM »
So I just ordered a set of the XVs on Ebay. for $179.  I'm going to install them before or as I'm installing the rear floor pans so I can get the angle right.  I'll post pics in my thread as soon as I install them.
Offline 1970RTSE
« Reply #103 on: September 02, 2008 - 12:21:55 PM »
How does the emergency/parking brake cable fit with the frame connectors?  Is there a slot? Or under?
Offline CHUCKS71
« Reply #104 on: September 02, 2008 - 05:19:12 PM »
I'm going to cut a hole and weld a piece of tube through the connectors.
