dutch 1970 cuda
Author Topic: dutch 1970 cuda  (Read 162235 times)
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: dutch 1970 cuda
« Reply #270 on: May 16, 2010 - 04:06:37 PM »
 :cheers: Bart you have earned a cold one buddy for some nice work!
Go Fast & Have Fun...
Offline dutch
Re: dutch 1970 cuda
« Reply #271 on: May 17, 2010 - 03:06:42 AM »
thanks guys , the more parts are done the more I want to not stop...  :bigsmile:
installed the quarterglass and rear window.  :bigshades:
*** Bart ***
Offline ShelbyDogg
Re: dutch 1970 cuda
« Reply #272 on: May 17, 2010 - 01:57:56 PM »
Bart,
I can't tell, but I hope that you black primed the entire area under the class before installing the window. Something I learned long ago.
If not, you will see color when looking at the glass from behind.
Offline dutch
Re: dutch 1970 cuda
« Reply #273 on: May 17, 2010 - 02:43:10 PM »
Bart,
ofcourse I did....  :grinno:  :violin:
well... it`s not that big a problem.  I was planning on using PU on the inside to make a clean cut between glass and trim.  I`ll primer it black before applying.
*** Bart ***
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: dutch 1970 cuda
« Reply #274 on: May 17, 2010 - 02:46:14 PM »
When is it suitable to come over for a testdrive? :smilielol:
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline dutch
Re: dutch 1970 cuda
« Reply #275 on: May 17, 2010 - 02:49:17 PM »
any time now Per... any time...  :roflsmiley:
*** Bart ***
Offline JayBee
Re: dutch 1970 cuda
« Reply #276 on: May 17, 2010 - 05:32:01 PM »
I just love checking on your progress.
Clever way you posed a tire in there also, too many people bugging you about the dolly wheels  :lol: .
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline dutch
Re: dutch 1970 cuda
« Reply #277 on: May 28, 2010 - 09:03:55 AM »
 :lol2:
fixed the blowermotor which came in pieces with the car. Boy ,am I glad I didn`t start with a project someone had already taken apart.
fixed the wipermotor ,I just need to get some grommets to bolt it to the car.
cleaned the Dana inside out.  The gears left a good print   :clapping:
I cut off the springpads since they were in the wrong position and Very badly welded. I will tack those in place when all weight is in place.
*** Bart ***
Offline Challenger III
Re: dutch 1970 cuda
« Reply #278 on: May 28, 2010 - 10:16:39 AM »
 :2thumbs:  :bigshades:  :2thumbs: Very nice!
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline Sean
    • My Cuda Restore
Re: dutch 1970 cuda
« Reply #279 on: May 28, 2010 - 10:40:11 AM »
Looks great!  That rear end looks almost too good to put back under the car!
Sean
Offline JayBee
Re: dutch 1970 cuda
« Reply #280 on: May 28, 2010 - 12:10:47 PM »
Don't forget the bushings that go into the grommets either, but you probably thought of that already.
John
2014 Toyota Avalon
Offline dutch
Re: dutch 1970 cuda
« Reply #281 on: May 28, 2010 - 02:36:13 PM »
thanks John,..the grommets were toast but all bushings are fine.  I made the grommets tonight from a piece of hydraulic rubberhose...  works great and motor is in now.  :cooldancing:
*** Bart ***
Offline swede-cuda
Re: dutch 1970 cuda
« Reply #282 on: May 28, 2010 - 02:38:38 PM »
 :clapping:kim at PASSION FOR MOPARS has the 3speed grommets and the inserts and the lower clamp for the cables,thats where i got my parts from.the only place i know of that sells the small (and big)parts for a doityourselfkindofperson. :woo:
Offline ArcticCuda
    • Pepe
Re: dutch 1970 cuda
« Reply #283 on: May 30, 2010 - 02:53:42 AM »
WOW! You have got DANA?  :bigsmile:
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
Re: dutch 1970 cuda
« Reply #284 on: May 30, 2010 - 03:43:23 AM »
That will be one very nice Cuda Bart. :2thumbs:
Per
