dutch 1970 cuda
Author Topic: dutch 1970 cuda  (Read 162173 times)
Offline dutch
Re: dutch 1970 cuda
« Reply #555 on: April 04, 2013 - 05:16:01 PM »
thanks.   Stock springs.  I have the koni`s up front and they feel good ( at least that half mile with 348 road bumps  ::)  )  I read about the eddy`s and most seem to like the firm ride, but this was awefull... felt like a go-cart in the rear.  I`ll see what happens after some miles... if there`s no improvement I will swap to koni`s in the rear as well.   :2thumbs:
*** Bart ***
Offline dutch
Re: dutch 1970 cuda
« Reply #556 on: April 05, 2013 - 01:18:31 PM »
 :faint: my goodness..... at times I`m such a dumb a$$  :bricks1:
My rear still needs a pinion snubber. Somewhere down the road ,I put a couple long bolts in the holes for the snubber.... but never took em out  :violin:
Those Eddy`s don`t feel half bad  :bigsmile:
Got her aligned today and drove around the block for the first time  :cooldancing:  everything worked the way it should and it was awesome to see people smile everywhere I passed.  Took me almost 6 years to get there, but thats all forgotten now ,... well almost.
One thing I don`t like is how light the steering feels... Rebuilt the box and it does not have any play, but it`s soooo light.  Is there a way to reduce pump pressure, or any other trick to get some more feel?
« Last Edit: April 05, 2013 - 01:24:52 PM by dutch »
*** Bart ***
Offline ragtopdodge
Re: dutch 1970 cuda
« Reply #557 on: April 05, 2013 - 01:29:38 PM »
You can either get a heavier spring installed in your box (not sure anyone local to you knows how to do that).  Akin to what FirmFeel does to their boxes.
Or, not sure if this works, but get a Heidt's adjustable pump pressure valve.
http://www.summitracing.com/search/product-line/heidts-adjustable-power-steering-valves
Glad she rides nice now.   :thumbsup:  Car sure is stunning from pics.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline dutch
Re: dutch 1970 cuda
« Reply #558 on: April 05, 2013 - 01:42:49 PM »
I was thinking of something like that valve, but the ad says it works on rack& pinion only ?
*** Bart ***
Offline ShelbyDogg
Re: dutch 1970 cuda
« Reply #559 on: April 05, 2013 - 03:14:48 PM »
There was a Mopar article on how using the slant 6 pump made the steering feel a little better. It went as far as using a washer to get the right spring pressure if you didn't have a slant 6 spring. Do a google search for it and it will pop up.  What I do to get better feel in all of my Mopars, is to get rid of that 15" sheeting wheel and put in a 13.5" Grant wheel.  Feels like less play and easier to get in and out of.
EDIT:
Did a quick google search and found it here:
http://www.moparaction.com/tech/beep/PUMP_IT_DOWN-re-v1.4.pdf
« Last Edit: April 05, 2013 - 03:18:27 PM by ShelbyDogg »
Rob
Offline dutch
Re: dutch 1970 cuda
« Reply #560 on: April 05, 2013 - 03:49:58 PM »
 :2thumbs:
*** Bart ***
Offline EB3-GranCoupe
  • BP23 U0B
Re: dutch 1970 cuda
« Reply #561 on: April 05, 2013 - 07:14:41 PM »
I'm going to have to try that shim. that was a good article!  I went with a Firm Feel rebuild, but i still want a tighter feel to the steering. bigger tie rods are next on my list to do too.
Your care is looking great dutch!  glad to see you are one step closer to being on the road!
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: dutch 1970 cuda
« Reply #562 on: April 06, 2013 - 10:04:07 AM »
Hey Bart   :wave:
I am so happy for you  :drool:
your car has turned out great  :2thumbs:
Go Fast & Have Fun...
Offline dutch
Re: dutch 1970 cuda
« Reply #563 on: April 06, 2013 - 12:48:00 PM »
my new tyre valve caps   :bigsmile:
*** Bart ***
Offline RB2929
Re: dutch 1970 cuda
« Reply #564 on: April 06, 2013 - 07:04:21 PM »
Hi Bart,
Always glad to see your Cuda progress.
Your valve stems are cool. I think that they're illegal in Conneticut, though.
Forgot about the pinion-snubber?  Must be that Dutch beer.
Won't be long now and you'll be cruising the Cuda through Netherlands highways and embarrassing Porches!!
Take care
Ron
Offline ShelbyDogg
Re: dutch 1970 cuda
« Reply #565 on: April 06, 2013 - 11:05:43 PM »
9mm Luger ammo has been scarce around here lately. I've been to many gun and ammo stores around me and most of them sell out within 2 hours of stocking the shelves. I have 4 9mm semi-automatics and they don't like sitting idle for too long.
Rob
Re: dutch 1970 cuda
« Reply #566 on: April 07, 2013 - 12:12:36 AM »
Now that's something I gotta copy!
 :2thumbs:
Did you just slip them over the stem/cap or epoxy the regular cap into the 9mm case?
Offline dutch
Re: dutch 1970 cuda
« Reply #567 on: April 07, 2013 - 04:23:27 AM »
threads cut on the inside, they screw on like a plastic one.
*** Bart ***
Re: dutch 1970 cuda
« Reply #568 on: April 07, 2013 - 02:55:26 PM »
Wow. Didn't think there would be enough meat on 'em for that.
Offline dutch
Re: dutch 1970 cuda
« Reply #569 on: April 08, 2013 - 04:49:12 PM »
my list of things to do after my first 10 mile trip...
-first of all,  cooling.  gonna start with the cheapest and work my way up to the most expensive.  Check for air in the system, get me a new fan clutch and a new radiator.  I`m thinking a new aluminium, but I`m gonna get me a quote or two on replacing the core as I like the looks of an oem cooler.
-looks like there are 2 trans leaks.  Selector shaft seal and it seems to leak from where the speedo cable attaches.  Any one know from the head what is behind the round plate that could cause a leak there?
-steering pump pressure needs to come down.
-last but not least...still got a rather unhealthy sound coming from the dana.  I heard the noise before I tore down the car and talked to a rear end mechanic about it.  Advise was to everything else in the drive line in good shape before tearing down the rear, which I did ,but the noise is still there.  My guess is the inner pinion bearing is bad since it makes a kinda grinding noise on acceleration. Could be gear adjustment. we`ll see.....
 :working:
*** Bart ***
