Author Topic: wiper switch problems  (Read 5841 times)
Offline JayBee
Re: wiper switch problems
« Reply #15 on: January 05, 2008 - 02:52:38 PM »
Cuda Hunter
I have a '70 with original 2 speed wiper motor and original wiring (still). The part number on my switch is identical to yours (the larger left side one). My connector seems to look exactly like yours, see pics. Oh, and my wipers work fine. Looks like you have everything for a 2 speed set up. It should plug together fine.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline JayBee
« Reply #16 on: January 05, 2008 - 04:46:16 PM »
Cuda Hunter, here's some more info. Not all of the wires and connectors are used on switch/harness (with mine anyway). Look on the back of your switch and you'll see some small letters, some with numbers (I had to use a magnifying glass). You know, everytime I take that panel off and try to remember how the wiper switch plugs back has been a thorn in my side.
A - Red wire from grey connector
F2 - Green wire from grey connector
B/U - empty
P - Dark blue
B - Pink
H - Brown with tracer
The solid brown wire in the black connector doesn't go anywhere on my 2spd switch. Anyway, that's how it's getting plugged back in in the spring.
John
John
2014 Toyota Avalon
