Author Topic: Bent p/s pump pulley  (Read 1315 times)
Offline tumbob
« on: December 25, 2007 - 02:48:26 AM »
Anybody have any insight on a easy way to remove a bent pulley from a federal pump (has a round cap) without messing it up? Do I need to get thin face wrenchs or is it a other tool?
09 Challenger SE
68 Charger 383
70 Challenger Convertible 340
72 Cuda 340
Re: Bent p/s pump pulley
« Reply #1 on: December 25, 2007 - 04:40:33 AM »
there is a special puller tool , it is 2 C shaped shells that grab th efront flange & a threaded puller through the center , , you have to thread a bolt onto the center shft & use the threaded puller to press it back into place
« Reply #2 on: December 25, 2007 - 09:39:36 AM »
I think this is the tool. I bought one and it worked good. Just add a little liquid wrench on top where they meet. Then they come right off.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40749
« Reply #3 on: December 25, 2007 - 12:47:10 PM »
That is the tool TC
Offline tumbob
« Reply #4 on: December 25, 2007 - 10:41:03 PM »
Thanks for all the help, but after more research I need to verify what pump I really have...
09 Challenger SE
68 Charger 383
72 Cuda 340
Offline 426HEMI
« Reply #5 on: December 25, 2007 - 10:46:12 PM »
This will take off most pump pulley's that you run into.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #6 on: December 25, 2007 - 10:56:34 PM »
That is the early Saginaw oval neck pump
« Reply #7 on: December 26, 2007 - 07:47:45 AM »
    :iagree:
Yep, that's what I have.
« Reply #8 on: December 26, 2007 - 08:58:32 AM »
That's the pump style on my '73. My pulley cam off w/o a puller, just removed the nut.
« Reply #9 on: December 26, 2007 - 02:58:45 PM »
that type may have the keyway instead of the  press fit pulley
Offline tumbob
« Reply #10 on: December 29, 2007 - 12:48:27 AM »
Thanks CP, that's the info I needed, there are so many different pumps out there.....
09 Challenger SE
68 Charger 383
72 Cuda 340
Offline tumbob
« Reply #11 on: January 04, 2008 - 12:23:43 AM »
It was a keyway, found a correct pulley and installing was easy with the right sized tools, Thanks again CP!!
09 Challenger SE
68 Charger 383
72 Cuda 340
« Reply #12 on: January 04, 2008 - 04:25:52 AM »
 :2thumbs:
