Author Topic: girdles ??  (Read 2612 times)
Offline Oldschool
  • Member Since 9-05-06
Re: girdles ??
« Reply #15 on: December 27, 2007 - 03:01:57 PM »
(We need another word other than "girdle". Reminds me of fat old ladies! We need a macho name!)
Girders?   :roflsmiley:   :roflsmiley:     :bigsmile:
Ken  --  In Georgia
nivvy
Re: girdles ??
« Reply #16 on: December 27, 2007 - 03:23:51 PM »
how about
"BLOCK PLATE"    :bigsmile:
Offline cudabob496
Re: girdles ??
« Reply #17 on: December 27, 2007 - 05:30:52 PM »
Stud Brace, Cap Brace, Stud Bridge?  (Stud has a macho sound)
2011 Kawasaki Z1000
Offline hemiken
Re: girdles ??
« Reply #18 on: December 27, 2007 - 06:40:22 PM »
What about "Cap Walk Terminator" :stirpot: :woohoo:
Offline go-fish
Re: girdles ??
« Reply #19 on: December 27, 2007 - 07:20:08 PM »
"Nover-trunions", "Lower Wainshaft Conducer", "Latteral Dingle Arm Plane" ????
Offline cudabob496
Re: girdles ??
« Reply #20 on: December 27, 2007 - 07:56:30 PM »
Latteral Dingle Arm Plane?   Bathe thyself, thou mammering unchin-snouted milk-livered miscreant!
« Last Edit: December 27, 2007 - 09:22:05 PM by cudabob496 »
2011 Kawasaki Z1000
Offline go-fish
Re: girdles ??
« Reply #21 on: December 27, 2007 - 07:58:21 PM »
At least you didn't call me a Cottonheaded Ninny-muggins!
Offline common 27
Re: girdles ??
« Reply #22 on: December 27, 2007 - 11:31:30 PM »
  I don't mind the name girdle,do they still even make them for fat women? I think we should come up with a better name for fat women,....Any way I wasn't planning to use studs either.Figured on just using ARP bolts. Do studs make a difference in strength? Seems like they would be the same as far as that goes if they are made of the same material. Also would a "GIRDLE" 3/16 of an inch effect the bolt lenght enough to make it unuseable?
1970  Challenger Convertible   1968 Satellite Convertible
Re: girdles ??
« Reply #23 on: December 28, 2007 - 01:28:42 AM »
the bolts sit far below/ above the girdle , you cannot tie the main caps to the girdle without using studs , so you need a set of extra long studs , nuts to hold the cap into place & then washers to shim to the girdle & a second set of nuts to hold the girdle onto the studs , the extra long studs is what I am having problems sourcing
Offline hemiken
Re: girdles ??
« Reply #24 on: December 28, 2007 - 01:57:52 AM »
Hi C/P,
I think 440 source will sell you the longer studs seperatly if you contact them. :2thumbs:
Re: girdles ??
« Reply #25 on: December 28, 2007 - 02:31:51 AM »
Thanks I can check it out
 I have 5 girdles sitting
Offline cudabob496
Re: girdles ??
« Reply #26 on: December 28, 2007 - 05:02:37 AM »
Strength wise, studs, instead of bolts, are the way to go for Main Caps, so I have been told. When building my Cuda, I was told to use studs instead of bolts, so the big block could handle the power.
2011 Kawasaki Z1000
nivvy
Re: girdles ??
« Reply #27 on: December 28, 2007 - 06:11:30 AM »
agreed!! I was running studs before having the lower block main protection stud plate shock inihilator installed!  :bigsmile:
