Author Topic: Installing electric fuel pump - do I need a relay?  (Read 9675 times)
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« on: December 25, 2007 - 11:34:40 PM »
I installed a gear drive for my camshaft, which precludes using a mechanical fuel pump. So, I bought an electric one. The instructions say it must be "fused at 3.0 amps." Does this mean I need a relay? Anyone have a particular relay in mind?
Offline GoodysGotaCuda
Re: Installing electric fuel pump - do I need a relay?
« Reply #1 on: December 26, 2007 - 12:17:19 AM »
Absolutely run a relay, any automotive relay radio shack or something has.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: December 26, 2007 - 02:27:22 AM »
I agree why not use a relay , although 3 amps is a very low load for a std switch
« Reply #3 on: December 26, 2007 - 07:51:26 AM »
A standard switch should handle 5 amps without a problem. It's your call as to useing a relay or not.
« Reply #4 on: December 26, 2007 - 10:54:35 AM »
more consistant voltage, keeps the heavier wires out of your dash and such. you can trigger the relay from the ignition key to run the fuel pump if you want it more convienent. The amperage will likely spike everytime its switched on, probably 7amps or so. The constant pull of the pump is 3amps. just my 2cents
1976 Dodge Warlock
nivvy
« Reply #5 on: December 26, 2007 - 12:10:18 PM »
I dont have a relay on my 499.... no problems yet but I may run one in the future!!! I use a fuse panel that is activated on the the key and of course fused!!!!! I also have toggle switch hidden that turns off the electric fuel pump... kinda like a anti-theft device....
What watt fuse do you guys reccomend that I should be running my electric pump???
Also I am getting ready to run my electric water pump to free up some HP  :smilielol: I guess you reccomend realying that as well...
« Last Edit: December 26, 2007 - 12:13:19 PM by StRoKer »
« Reply #6 on: December 26, 2007 - 03:01:01 PM »
Definatly use a relay on the wate pump & 15or 20 amp fuse for the fuel pump
Offline BruteForce
« Reply #7 on: January 02, 2008 - 03:45:43 PM »
I just ordered relays from www.allelectronics.com. It's hard to beat the price at $2.40 for the relay and $2.00 for the socket. Part numbers RLY-351 and SRLY-2
Offline BruteForce
« Reply #8 on: January 13, 2008 - 01:53:37 AM »
I finally got the fuel pump itself installed. I was originally going to stick it in the engine compartment, but eventually thought it would be better off next to the tank. I put in an upstream prefilter.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #9 on: January 13, 2008 - 03:55:26 AM »
Have you tryed it out, yet..???
I see no rubbers between pump and car...???
I got rubbers between there on my car, anyway the pump make all of the car shakin, and make a terrible noice..!!!
 :stomp: :pullinghair:
« Reply #10 on: January 13, 2008 - 04:35:09 AM »
filters on the suction side are a bad idea , clean it often
Offline BruteForce
« Reply #11 on: January 13, 2008 - 04:57:31 AM »
I haven't tried it out yet - I won't put gas in until the engine is ready to run. I hadn't thought of using rubber washers, it's a good idea. I've also seen other setups that had extra filters on the input side. Well, if it doesn't work, it's easy to take out. With the glass part of the filter, I can at least see if it's working.
The relay is now mounted under the dash. I haven't put the wiring or switches in yet.
Offline hemiken
« Reply #12 on: January 13, 2008 - 06:41:07 AM »
Hey Brute,
I personally would not use the glass filter you have as they are prone to break easily especially where you have it mounted, a rock or stone could smash the glass.  These glass filters are sometimes marked incorrectly for gas flow aswell.  You should try blowing through the filter to work out which way it should be mounted.   Take my word for it as i have found these filters on many hotrods and people scratching their heads trying to work out why the gas will not keep up to the carburetor.  Well worth checking. :clapping:
« Reply #13 on: January 13, 2008 - 08:19:40 AM »
My filter is on the suction side, and it is huge. No issues with mine so far. Also be leery of that glass filter like said...
1976 Dodge Warlock
Offline 422STROKER
  • Member Since 6/3/06
« Reply #14 on: January 13, 2008 - 11:23:07 AM »
I had a glass filter break under the hood of my 66 Charger, wasn't pretty.  Luckily for me I was home and a wash bucket was close. :22yikes:
Tom
Pump looks good, I would put a couple of Rubber Bushings for sure. :2cents:
Tom
