How can I improve on factory electrical system?
Author Topic: How can I improve on factory electrical system?  (Read 3139 times)
Offline mikeinsjc
« on: December 26, 2007 - 03:41:17 PM »
I would be interested to hear from anyone regarding any modifications/improvements they have made or might recommend to the factory electrical system. The car is a 70 Challenger 383. The only thing I have done to date is to bypass the factory ammeter gauge (will replace it with a voltmeter). I have heard this will also make the lights a little brighter, as all electrical load runs throught the original factory ammeter. What else would you guys recommend? Would a different alternator, or a headlamp relay help?
70 cuda
70 challenger
69 6 pack rr
Re: How can I improve on factory electrical system?
« Reply #1 on: December 26, 2007 - 03:46:06 PM »
definatly do the headlight relay
Offline mikeinsjc
« Reply #2 on: December 26, 2007 - 03:53:55 PM »
Where can I get a headlight relay?
70 cuda
70 challenger
69 6 pack rr
Offline FJ5_440
  • Wisconsin
« Reply #3 on: December 26, 2007 - 04:05:04 PM »
Try:
http://www.madelectrical.com/catalog/rly-1.shtml
They are not the cheapest way to go, but the kit was complete and has been very reliable. :2cents:
** Shane **
Offline mikeinsjc
« Reply #4 on: December 26, 2007 - 04:34:33 PM »
Are there better alternators on the market besides the stock unit? Are single wire alternators any more reliable? Also, are all voltage regulators created equal? My car is all stock but I don't care if these components aren't.
70 cuda
70 challenger
69 6 pack rr
Offline backtobasics
« Reply #5 on: December 26, 2007 - 05:34:42 PM »
Powermaster makes a 1 wire alternator, that is voltage tested, and much better then stock. Lights are brighter, and it is in a stock case, so the modification is barely noticeable.
Offline alphabuck
    • Pics of my project
« Reply #6 on: December 26, 2007 - 05:41:11 PM »
i sell a self exciting single wire alternator at my shop.  its a delco.  lester number 7127se. cheap one thats around 40 amps is around 50 bucks.  got a 63 amp version for like 75 and theres even a 100 amp model out there.
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #7 on: December 26, 2007 - 08:05:33 PM »
you can buy the parts from MCM Electronic for about 10 bucks.
« Reply #8 on: December 27, 2007 - 02:17:17 AM »
any 4 or 5 pin 30 amp realy will work , you can run 1 under dash before the dimmer or run a pair out by the starter relay
Offline vert
  • Looking good, Billy Ray! Feeling good, Louis!
« Reply #10 on: January 01, 2008 - 09:58:34 PM »
Actually the MAD site explains that the one-wire is inferior to the 3-wire.
71 Barracuda | Hemi idling | Hemi Dyno pull
« Reply #11 on: January 01, 2008 - 10:35:45 PM »
the small Denso alt pkg 440 Source sell is a nice unit , it will put out 30+ amps @ idle
Offline scf100
  • FAST LANE FOREVER!
« Reply #12 on: January 14, 2008 - 10:33:11 PM »
on my 70 Challenger I bit the bullit and bought the updated/modified front engine harness from YearOne and put a new Powermaster Alt on.....everything works great and no dim headlights.....my orig harness had been butchered over the years..
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
