Author Topic: Neutral start switch - same for 904 and 727?  (Read 1188 times)
Offline OzCuda
« on: December 27, 2007 - 06:55:40 PM »
Having fitted an earlier (66) 383/727 to my 70 318/904 Barracuda, the Neutral start switch no longer matches the wiring loom connector.  Will the switch out of my old 904 be a straight swap or are they different???  The loom is the 3-pin neutral-start/backup light version while the 727 currently has a single threaded pin with nut.
'70 Barracuda
Offline RD
    • KANSAS MOPAR CRUISE
Re: Neutral start switch - same for 904 and 727?
« Reply #1 on: December 27, 2007 - 10:06:57 PM »
the three pin will be a straight swap from your 904 to 727
Eskridge, Kansas (32 Miles SW of Topeka, KS)
Offline tactransman
« Reply #2 on: December 27, 2007 - 10:11:42 PM »
I have successfully changed the 3 wire/1 wire switches between cases.(screwed the one out and replaced it with the other)  Even though the valve body is a little different on the inside where the pin on the switch touches,they have always worked.
« Last Edit: December 28, 2007 - 06:33:03 AM by tactransman »
Terry-tactransman
Union, Mo.
Offline OzCuda
« Reply #3 on: December 29, 2007 - 06:12:05 AM »
Thanks  :thumbsup:
'70 Barracuda
Offline hemiken
« Reply #4 on: December 29, 2007 - 06:58:42 AM »
Just make sure you check the depth of the plug you pull out with the plug you are fitting buddy. :2thumbs:
Offline oldkimmer
« Reply #5 on: December 30, 2007 - 05:44:21 PM »
..................With that 3 wire switch ur back up lights will also b on in drive, as well as reverse.......kim.....
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline OzCuda
« Reply #6 on: December 30, 2007 - 09:23:34 PM »
So the 3 wire switch works differently on different transmissions??  Will be original switch connecting to original loom.
'70 Barracuda
Offline oldkimmer
« Reply #7 on: December 31, 2007 - 12:13:30 PM »
............................The linkage inside the trans is all metal , whether in Dr or Rev it makes the connection to the switch...........on 69 up trans there is a plastic coating preventing the BU lights from coming on.....U could switch out the linkage.......kim...... :canada:
