Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
another rearend question....
« previous
next »
Print
Pages: [
1
2
Author
Topic: another rearend question.... (Read 2225 times)
challenger71
Jr. Member
on:
December 27, 2007 - 09:44:51 PM »
I have the possibility of getting a suregrip (wheels spin opposite direction) out of a 73 roadrunner. Can I take that rearend and put it in my Challenger, or do I have to just take the 3rd member out and swap them? I too, do not know much about rearends (insert pun).
Logged
10 years in the making......
Chryco Psycho
Administrator
C-C.com Guru
Re: another rearend question....
Reply #1 on:
December 27, 2007 - 10:32:20 PM »
the sure grip will rotate both tires in the same direction , if they are opposite it is not a sure grip
the whole carrier can be swapped if both are 8 3/4 or the sure grip alone can be swapped into your gearset again if both are 8 3/4 " diffs
Logged
challenger71
Jr. Member
Reply #2 on:
December 28, 2007 - 09:49:16 PM »
Thanks....I was reading the other forum about rearends and I was more confused after I was done. All I really needed to know was if it is a sure-grip, do the tires rotate the same direction or opposite. And the answer is the same direction.
Logged
challenger71
Jr. Member
Reply #3 on:
December 28, 2007 - 09:54:43 PM »
Well I guess I am confused again. Here is a direct quote from the seller: "when I spin the drive shaft yoke both spin the same way but when I spin the axle the other one goes inthe opposite direction."
So would this be limted slip or open?
Logged
hemiken
Sr. Resident
Hemi-fied Mopar in Australia
Reply #4 on:
December 28, 2007 - 09:55:06 PM »
Off topic, But thuoght you may apreciate your avatar made to a more useable size if you want to save it as.
Logged
1970 Barracuda (O^--^===|===^--^O)
1971 Barracuda (O O {]{]{]|[}[}[} O O)
1970 Challenger (O O [======R/T=] O O)
1971 Challenger (O O ===== ===== O O)
hemiken
Sr. Resident
Reply #5 on:
December 28, 2007 - 09:57:33 PM »
Your diff is an open center diff.
When turning a wheel the other wheel will turn in the same direction for a limited diff center.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
December 29, 2007 - 01:43:48 AM »
with any sure grip turning 1 wheel the other has to go the same rotation , if it goes opposite it is open
Logged
challenger71
Jr. Member
Reply #7 on:
December 30, 2007 - 04:49:27 PM »
Ok thank you. I now understand. My next question is, what is better or stronger, the clutch or cone style limited diff?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
December 30, 2007 - 09:34:05 PM »
Clutch is the better design
Logged
moper
Resident
Reply #9 on:
December 31, 2007 - 09:13:18 AM »
I'll only add to the sure grip note on spinning the tires by hand "unless it's already destroyed...". If the grip is shot, it behaves like an open differential.
Logged
hemiken
Sr. Resident
Reply #10 on:
December 31, 2007 - 09:15:00 AM »
Good point
But doesn't it feel notchy and drags a little when broken
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #11 on:
December 31, 2007 - 11:35:43 AM »
no , the cones type will bottom out & have virtually no resisitance left , however might as well treat it as a open as there is no way to repair a worn out cone type , you just throw them away
Logged
hemiken
Sr. Resident
Reply #12 on:
December 31, 2007 - 11:38:50 AM »
I know guys who have done some kind of welding to build something up on cone style sure grips and they have worked. Do not know how long for as i have not kept in touch for a long time.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #13 on:
December 31, 2007 - 11:41:25 AM »
you can machine .100 or more off the end of the cones & add shims to the springs to try to extend the life of the cone style , how well it works is up to debate I guess
Logged
challenger71
Jr. Member
Reply #14 on:
January 02, 2008 - 08:43:56 AM »
I have the possiblity of getting a cone style that is 20 miles from my house (no shipping) for just over $400. It has 3.91 gears and rotates good, and the teeth are perfect. It also has a 742 case. Which case is better, the 742 or the 489?
Logged
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
