Author Topic: Clearing out the shop...  (Read 1351 times)
Offline moper
« on: December 28, 2007 - 03:35:01 PM »
All stuff is for sale:
Big block:
Indy Cylinder Heads std port window SRs. Complete package, never installed, but taken apart a while ago. Includes script valve covers, 1.5 roller rockers and shafts, breather kit, oil line kit, Manley head botl pkg, and two head assemblies taken apart. From sitting, they will need the valve seats touched up, and the decks should be milled to get the right finish. Intake ports are std size (not max wedge) so any B/RB intake fits, exh ports are raised, so special headers are required. $1800.00 firm, possible to seperate head pkg from other stuff. Possible to get them ready to bolt on with springs matched to your cam for extra $$.
M1 B wedge single plane with Dominator flange- New - $250/mo
Edelbrock B wedge 6bbl - New - $200
Weiand B wedge dual plane 4bbl (I think pn 8008?) -used- $100
Crane 1.5 rockers and shafts - used- $150
440 block, passed mag, cleaned, rough bored .058 over, ready for hone and decking - $200
440 block, was running engine - .030 over now, needs mains align honed - $100
400 shortblock, std bore but stuck - $150
LA/Magnum Small block:
'70 340 std bore block, airless shotted, one sleeve from pin marks in bore, passed magnaflux - $500/mo
'97 5.2L Magnum block only- std bore, includes spider, lifter retainers, cam retainer, oil filter plate - $100
'97 5.9L Magnum long block- std bore, stuck, heads off it, includes spider, lifter retainers, heads have visible cracks - $150
'93-? Magnum V8 heads- completely redone with stock parts, Serdi valve job, ready for your rockers/hardware - SOLD
'73 340 4.070 bore (.030 over) cast stock replacement pistons w/pins, light wear - $50/set
'71 340 Thermoquad intake - needs cleaning - $150
'72 340 Thermoquad intake - needs cleaning - $100
Car parts:
'73 E body non AC heater box - replaced heater core one year ago, some damage on lwer edge of cowl air passage, functional, but not pretty - $100/mo
'72 4bbl small block air cleaner assembly, single snorkel w/ rear flapper door in base - $100
'71 4bbl 340 only air cleaner - has no snorkels, just two oval holes - $300
Competition Engineering Weld-in 8pt Cage kit for E body - might be missing a couple plates or gussettes, I have to track them all down, otehrwise brand new never installed -SOLD Thanks Gary.
PM me here, or email me at Dmador@Travelers.com  If you don't like the prices, make an offer, you never know..
Thanks
« Last Edit: January 08, 2008 - 12:27:59 PM by moper »
Offline moparnocar
Re: Clearing out the shop...
« Reply #1 on: December 28, 2007 - 05:48:22 PM »
where are u located??
Offline 71340RT
« Reply #2 on: December 28, 2007 - 06:14:21 PM »
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
« Reply #3 on: December 28, 2007 - 07:21:38 PM »
I'd take the 72 340 sb air cleaner if it isnt all rusted up and in good condition, :2thumbs:
Offline cudazappa
« Reply #4 on: December 28, 2007 - 10:46:27 PM »
i sure could use the cage... you've got an email..
2015 Dart GT - Daily Driver
Offline moper
« Reply #5 on: December 31, 2007 - 09:09:16 AM »
Zappa I replied to you. I'll send you a note Wednesday. Al, I'm in Columbia CT, 06237. About 30 minutes east of Hartford.
