Author Topic: How many quarts of fluid needed during filter change on 904?  (Read 3905 times)
Offline quagmire
  • Traction Impaired......
« on: December 28, 2007 - 05:23:48 PM »
Hi again, I have a pretty simple and random question.  Does anybody know how many quarts of ATF are needed during a filter change on a 904 trans?  I have a Lokar trans dipstick and I want to make sure the dipstick is accurate, seeing as my engine oil one was about 1.5 quarts overfilled when it read normal.   :eek4: Thanks! -Dan
Offline GoodysGotaCuda
Re: How many quarts of fluid needed during filter change on 904?
« Reply #1 on: December 28, 2007 - 06:24:51 PM »
Kind of hard to say as far as that goes. Transmissions can easily drain a quart or so extra depending on how long you let it sit with the pan off. Tactrans may have a better answer, just my 2cents! :cheers:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline tactransman
« Reply #2 on: December 28, 2007 - 08:46:00 PM »
Dan,when you drop the pan on a 727 or 904,it usually takes about 4 Qts to fill it up. To test for accuracy,with the transmission in neutral, idling on a level surface, if you did not have a filler tube in the case , the fluid would be right at the top of the filler tube hole.
Terry-tactransman
Union, Mo.
Offline quagmire
« Reply #3 on: December 28, 2007 - 09:01:51 PM »
Good deal, I'll have to check it that way then.  I'm worried that this dipstick maybe inaccurate too, and I'm sure the trans overfilled 1 quart would probably suffer quite a bit more than the engine from aerated fluid.  Thanks!
