Author Topic: Power Steering Pump Replacement  (Read 875 times)
Offline Madmax440
« on: December 28, 2007 - 11:38:07 PM »
My power steering pump or lines have a leak and I need to replace. Since I am so attracted to shiny things - Will this one from March work ???
http://www.marchperf.com/pg52.html
Also, I will be replacing the radiator before spring with an Aluminum radiator and fans - Any suggestions here ???
Btw - Fans don't have to be shiny, but it helps.
Would also like to go to a nice (shiny of course) electric water pump while I am at it.
All suggestions help - Thanks.
While I am
Re: Power Steering Pump Replacement
« Reply #1 on: December 29, 2007 - 01:41:32 AM »
the PS pump should work fine , iti is a Saginaw pump
, the most effecient fan system is the Factory clutch fan with a shroud period
 WHy are you replacing the rad ?, if you must go Alum get a welded not gluded type , Be Cool have a great product but pricy , Summit has a cheaper line of welded rads
« Reply #2 on: December 29, 2007 - 06:35:07 AM »
About the power steering pump... I just hate it when they say "modifications to your brackets MAY be required".   :pullinghair:
I don't know of anyone useing this pump right now. Sorry.  :sadwavey:
