Author Topic: Mopar Polished Valve Covers (painted)  (Read 1467 times)
nivvy
« on: December 29, 2007 - 06:25:42 PM »
Anyone have a set that has been painted inside the ribs.... or know how to do it???
Kinda like the pic below but not with the letters painted??? Im thinking of going this route!!!
Polished chrome mopars with body color inside the ribs.........can anyone here do this for me if I buy a set ???  :money:
Offline 6packCuda
Re: Mopar Polished Valve Covers (painted)
« Reply #1 on: December 29, 2007 - 06:34:26 PM »
That would look nice too. :2thumbs:
Offline Carlwalski
« Reply #2 on: December 29, 2007 - 06:50:26 PM »
:iagree: That would look nice, different too. :2thumbs:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline MJS73
    • Mike's 1973 Challenger
« Reply #3 on: December 29, 2007 - 07:47:41 PM »
Here's mine:
www.mikes73.com/engine.html
(you can see them in my signature, too)
« Last Edit: December 30, 2007 - 08:28:59 AM by MJS73 »
www.mikes73.com
Offline Black340
  • 1973 challenger 340 4 Speed
« Reply #4 on: December 29, 2007 - 07:51:06 PM »
Mike they look great :2thumbs:
Offline FJ5_440
  • Wisconsin
« Reply #5 on: December 29, 2007 - 08:55:15 PM »
I used to run M/T valve covers painted like that.  Pretty easy to do, just tape off the areas outside the ribbed section.  Then spray the ribbed area and let it dry so it is no longer tacky.  Finally, stretch an old diaper dampened with solvent tightly over a sanding block, and carefully wipe off the tops of the ribs.  You might need to do a little finesse work with a Q tip moistened with solvent, but it is really pretty easy once you get the hang of it.
** Shane **
Offline moparclown
« Reply #6 on: December 29, 2007 - 09:46:08 PM »
Did anyone else see the big wad of blue goop around the thermostat housing? :roflsmiley:
I love the rest of that engine compartment.
Mike your engine compartment is swweeeeeeettttt
Offline 71340RT
« Reply #7 on: December 30, 2007 - 02:15:21 AM »
Looks like blue silicone squeezed out around the thermostat housing.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
« Reply #8 on: December 30, 2007 - 07:22:30 AM »
My guess is a homemade rubber gasket.   :clueless:
Offline MJS73
« Reply #9 on: December 30, 2007 - 08:26:26 AM »
But it doesn't seep anymore!
www.mikes73.com
Offline MJS73
« Reply #10 on: December 30, 2007 - 08:30:31 AM »
Thinking about going to the black wrinkle ones (car is white w/black).  I did the orange to match the block which, of course, you can't see.
www.mikes73.com
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #11 on: December 30, 2007 - 10:09:49 AM »
Looks nice, I think Redline did this, but I forget just what procedures he went through. It seems like a project that would require a lot of time. But the out come when done right is   :2thumbs:  knockout.  I'm wondering if using a sponge applicator or Q-tip, if ya put a layer of say vasiline on the ribs then usung a low pressure gun paint the cover. When dried the vasiline should wipe off with any paint residue upon it ? ?
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline miketyler
    • www.miketyler.net
« Reply #12 on: December 30, 2007 - 10:51:39 AM »
Its easy to do, I did mine by spraying then wiping off the raised areas. However, I took it a step further as I wanted to preserve the polished finish and clear powder coated the entire assembly. I wanted to do the same with the MP cast air cleaner lid but the metal they use to cast those is not as high a grade as the valve covers and will not polish up tothe same finish. I had mine vacuum plated, and then carefully masked off the raised ribs and lettering before painting. Its holding up very well and looks very similar to the finish on the valve covers now.
For the final touch, I dyed the white air cleaner element purple.  :2thumbs:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
nivvy
« Reply #13 on: December 30, 2007 - 10:55:35 AM »
How do you polish like that??
Offline miketyler
    • www.miketyler.net
« Reply #14 on: December 30, 2007 - 11:02:31 AM »
in the case of the MP cast air cleaner, you don't. Its made of a lower grade metal and doesn't polish up to the same microfinish as the valve covers. I considered chrome but it would be too shiny and wouldn't match the valve covers. I had it vacuum plated. It has since dulled down some and matches the valve covers nicely.
72' Cuda restomod
70 Mustang Mach 1
