Author Topic: How to get 10" rims to fit on an E-body Cuda?  (Read 2160 times)
Offline johnhuckin
  • 73 'Cuda
    • John Huckin's 73 Cuda
« on: December 29, 2007 - 07:37:41 PM »
Hi all. I know this has probably been thrown around before but I thought I would start a new post.
Can any of you E-body owners show/explain how you got a 10" or wider wheel and tire setup to fit without tubbing. Thanks in advance.  :thumbsup:
nivvy
Offline jeryst
Re: How to get 10" rims to fit on an E-body Cuda?
« Reply #2 on: December 29, 2007 - 08:03:16 PM »
Get a set of air shocks, and you can put on anything you want. I had a 73 Cuda back in 73, and I had 10" deep dish Cragars on it with 50 series tires.
Offline Carlwalski
« Reply #3 on: December 29, 2007 - 11:51:41 PM »
Correct BS. ;) What size tires are you going or wanting to run? 95% chance you can get away with 275's and save yourself the guess work. 275s are the standard "big" rim for these cars. I'll be running a 15x10" cop rim with 5-1/2" BS on my 'Cuda Madeline once complete. I trial fitted these tires/rims prior to strip down with 275s (as planned) and they fit perfectly. I had no choice in going the 10" size rim as they didn't offer an 8" cop wheel rim.
Remember, when you start talking in 1/4" to 1/2" gaps between springs and fender lip that each car is different. These cars gaps aren't all the same, some have more, some have less, it's minute but can make a difference. Just because one guy made them fit without mods doesn't mean it'll fit another car 100%. Usually but not always, just keep that in mind.
:2cents: :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #4 on: December 30, 2007 - 04:29:39 AM »
the best way is to run a 17" or larger diameter rim the minimise sidewall buldge
using a 295/50/15 they will rub , the 8 " rim pulls the sidewall in enough to fit in most cases
Offline miketyler
    • www.miketyler.net
« Reply #5 on: December 30, 2007 - 08:55:09 AM »
What rim/tire are you wanting to run? CW is right, these cars can vary a lot when you try and maximize tire size and minimize clearances. I am hoping to stuff 315's under my car and will have to move the springs to clear the additional width of the tire. I plan to run a lower profile tire with 1/4" to 5/16" clearance on the springs and even still may require fender lip rolling.
You will do very well to go and measure your backspacing before you buy your wheels and tires. I have read several accounts where guys are running 275's with 5.5BS on the rear with no mods.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Samuelson1022
« Reply #6 on: December 30, 2007 - 01:22:52 PM »
I decided to go the shelby dog route and purchase a B body 8 3/4" rear end.  Using a mopar performance 3/4" relocated shackle kit and new Super stock leaf springs from mopar, the b body rear end dropped right in.  The new rear end is shorter overall allowing 15x10" rims  to fit with 5.5 inch backspacing for a tucked look.  Check out Shelby Dogs latest post in the Tire set up thread posted by Stroker to see his set up.  Thanks, Sam
