Author Topic: Cold Air Intake on new 6.1?  (Read 538 times)
Offline Confederate Cuda
« on: December 29, 2007 - 10:21:55 PM »
does anybody know of a cold air system that will fit? i'm expecting to do a little cutting, but I was just wondering if there was a premade kit I could use instead of having to make one myself.  Thanks guys.
Offline cudabob496
Re: Cold Air Intake on new 6.1?
« Reply #1 on: December 29, 2007 - 11:40:54 PM »
2011 Kawasaki Z1000
Offline Carlwalski
« Reply #2 on: December 30, 2007 - 12:00:04 AM »
Mopar make one too. Dad put one on his SRT8 300C and holy crap, they make a big difference. Interior sound is dramatically increased under throttle and exterior noise is also, not as much as interior though. Performance and response is also very noticeable. You have to wonder why Chrysler/DC never put them on the car as standard......
:2cents: :wave:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline cudabob496
« Reply #3 on: December 30, 2007 - 04:40:12 AM »
You gain 1% power for every 10 degrees you lower the carb inlet air temp. So on a 500 horse engine, if you lower the temp of the air into the carb by 50 degrees (which ain't hard to do, as hot as it gets in engine compartments), you will gain 5% power, or 25 hp! I have a ram air box on my Cuda. It cost about $150, but gives me about a 30 hp increase.
2011 Kawasaki Z1000
