Author Topic: Trunk floor patch it or replace it?  (Read 3365 times)
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« on: December 30, 2007 - 03:30:55 PM »
My trunk floor has some rust by the tail panel and the driver side trunk extension.I need to replace the last foot and a half of the rear frame(soft) and I don't know what the best way would be.I just don't want to do it half a$$ed.I'm not rich by any means but I want it right what ever it cost.Thanks Chuck
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline CHUCKS71
Re: Trunk floor patch it or replace it?
« Reply #1 on: December 30, 2007 - 03:32:22 PM »
Here are some bottom pics.
Offline 426HEMI
« Reply #2 on: December 30, 2007 - 03:37:01 PM »
If it is not too thin I would most likely just patch it.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #3 on: December 30, 2007 - 03:41:57 PM »
Looking at the pics from the botom, it is worse than it looks. What looks like small pin holes will get much larger when you clean it up. Thats why I say replace it. The rear frame rails look like a safe-t-cap may cure that problem too.  :2cents:
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline Chlngrcrzy
« Reply #4 on: December 30, 2007 - 03:57:29 PM »
I had some rust in my trunk area, but it was located in a thin strip all along the rear of the tail panel. i am going to cut that out and lay a peice in there. I also have rust right along side the inside wheel wells, and those can be cut out and peiced back in. My trunk extensions are in worse shape, and i had to replace one of them. I would say that after you clean up the surface areas and see what you have, if you have some thin areas all the way around the trunk area similar to what i have, i would replace the whole pan. I am trying to blend in the repairs, but some of those tight angle areas are tough. If i could do it again, i would buy a complete trunk pan and be done with it.
Offline FJ5_440
  • Wisconsin
« Reply #5 on: December 30, 2007 - 04:00:15 PM »
I agree with Dave, by the time you get that all cleaned up, it will be worse than it looks now.  I would replace it, and sleep better knowing it was gone for good. :2cents:
** Shane **
Offline CHUCKS71
« Reply #6 on: December 30, 2007 - 04:04:01 PM »
Who did you use for the trunk extensions?Does the goodmark floor fit well?
Offline Chlngrcrzy
« Reply #7 on: December 30, 2007 - 04:12:06 PM »
I got my trunk extension through Paddock. It fit great.
Offline 71340RT
« Reply #8 on: December 30, 2007 - 09:23:05 PM »
Start cleaning it up and see how it looks. You may find that you will want to replace it once you get a good look at what is really there.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #9 on: December 31, 2007 - 10:01:51 PM »
i would suggest to replace it. When you factor in filling the pits and cutting out the bad area's and patching, rail ends, you will be farther ahead in labor costs to replace the whole panel, the trunk floor, floor supports, lock support, tail panel, rear rail sections NOT safety caps. I have in stock. i give 10% or better to C-C members. The big draw back to a full trunk replacement  is I hope your putting on a quarter panel. If not you will have to cut in half and stitch weld it back together. Other wise you can slide the whole trunk floor in from the right side with out any major issues. If you do that. make sure the spare tire bracket is welded in first. hope this helps.
www.rosevillemoparts.com
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline CHUCKS71
« Reply #10 on: January 01, 2008 - 01:54:05 PM »
Thanks for all the information I hope to get to the trunk in a few weeks. Chuck
