Author Topic: Going to paint  (Read 671 times)
bbscamp
Going to paint
« on: December 30, 2007 - 10:05:33 PM »
Sort of.   Since no one seems to want an unfinished project, that's a little more motivation to get'r done.  The 70 Chally (old S6/904/7.25  soon to be  440/727/8.75)  is going in for a color change too.  Gone will be the original B5 Blue, and on will go Limelight Green.   It will be done in 2 steps.
Step 1:  all jambs, trunk, engine bay all done in BC/CC.  Exterior to have all final fitment of panels and bodywork done, sprayed in epoxy prime.
 - then will come the mechanical build -
Step 2:  once built, back to paint for the exterior.  I like the T/A stripe without the T/A...and might get the decal.  The painter would like to do it in paint and CC over it.  Comments?
Offline 422STROKER
  • Member Since 6/3/06
Re: Going to paint
« Reply #1 on: December 30, 2007 - 10:16:10 PM »
My painter wanted to do the stripe under the CC as well.  I thought that I could always just remove the stripe if i didn't like it, or someone else later. :2cents:
Tom
Tom
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Going to paint
« Reply #2 on: December 30, 2007 - 10:24:04 PM »
Painting the stripe then clear coating it would look nice.  My black stripes and the hood scoops were done in black and then clear coated over 30 years ago.  I think it is a personal preference as to whether you like vinyl tape stripping or painted on stripes.   The vinyl decals will be a flat black color which can be a real pain when waxing the paint.  Vinyl can tear and peel also.  Depends on your taste.  I like the look of vinyl decals, but they require some TLC.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline LAA66
Re: Going to paint
« Reply #3 on: December 30, 2007 - 11:18:18 PM »
 I would hesitate to use a polishing wheel around tape due to burning or tearing. There always seems to be polish or wax on the tape margins too. Then it's toothbrush time, and a dust down. Just more work. :2cents:
