I dont like seeing them stuck to engine xompartments. So i mount them inside, or under teh battery tray. You may have to extend the wires for those, but it gives you the chance to seperate the pick wires from the power leads, as they can cause feedback problems. You will want to run the small red power wire to the box thru the oil pressure switch, as the brain doesnt have a small ground wire. I would not run the pickup wires thru that safety switch. Also, you may find it hard to start iof there is no oil pressure, like after sitting overnight. You'll have to turn over the engine first, get oil pressure, then it will trigger the ignition. Personaly, I dont want it to shut down unexpectedly...lol. Plus, once the switch sees the oil pressure loss, the engine keeps rotating due to driveline inertia. You cant do much to stop damage due to oil pressure loss, unless you run an accumulator system. I like Canton's Accusump.
