Author Topic: drive shaft length for 440-4 speed with Dana  (Read 3624 times)
Offline mopardave
  • Sponsor
    • rosevillemoparts
« on: December 31, 2007 - 09:44:10 PM »
We are putting together a 70 cuda with a 440+6 with a 4 speed with a Dana. What should the correct length for the drive shaft. the 727 8.75 shaft is about 44 1/2 ish, any help would be great,
thanks mopardave
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline ksierens
    • 70 Challenger Resurrection
Re: drive shaft length for 440-4 speed with Dana
« Reply #1 on: January 01, 2008 - 09:29:57 AM »
Dave,
I can measure my Challengers today, (Origional 440/4 speed Dana) but I think it is longer than a Cuda's.
Kurt - SE Michigan
Offline 422STROKER
  • Member Since 6/3/06
Tom
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: January 01, 2008 - 11:36:54 AM »
thank you for the replies,
happy new year to all
Mopar Dave
73 F8 Challenger
1990 XJ - sold
bbscamp
« Reply #4 on: January 04, 2008 - 09:36:10 PM »
I was looking at the book page you mentioned.   For the 70 Challys, it says 340, 383s are 45.60".  for all transmissions.  Next line it says 440/426 with automatics are 43.60".    The driveshaft part number given for each shaft is the same.  What gives?  I need to get a driveshaft for my 70 with a 440/727/8.75....but before I can get it made I need a GOOD measurement.  Which is correct??
nivvy
« Reply #5 on: January 04, 2008 - 09:41:51 PM »
what is the correct measurement... interested... I have a 440/727/8.75  :cooldancing: 72 challenger
Offline 422STROKER
« Reply #6 on: January 04, 2008 - 10:02:53 PM »
I think they are 2" OFF.
This has been discussed before, that is how i got the link. 440 has same tranny as 383, so they should be the same.  The only change may be if a Dana 60 was used instead of a 8 3/4.
Tom
Tom
bbscamp
« Reply #7 on: January 05, 2008 - 04:22:00 PM »
1)  So what is the correct length (C to C on u joints) for a 70 chally 440/727/8.75?
2)  Is this length different for the same combo in a 70 Barracuda?
3)  Is this length different than 71 and later Challengers?  did the wheelbase change between years and Ply. vs. Dodge??
 :popcorn:
Offline ksierens
« Reply #8 on: January 05, 2008 - 04:35:11 PM »
Dave,
Contact Joint Clucth and Gear by us.  They will probably tell you what measurement they need and will make one up for you.
http://www.jointclutchandgear.com/index_files/Page682.htm
Kurt - SE Michigan
