Thanks, you are correct, dies when the switch is let go, but I cant understand why it was OK tuesday? We fired the new motor using a remote starter clamped on to the starter relay posts, with the key in the run position. It worked fine, and the key would turn the car off. I just didnt have the neutral switch hooked up so the key would not START the car. I did cross some wires when I grounded that neutral switch, could THAT have caused the iggy switch to go bad overnight? I'' send you a picture of the wiring.....
