Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Brake upgrades from drum to 4 wheel disk.
« previous
next »
Print
Pages: [
1
Author
Topic: Brake upgrades from drum to 4 wheel disk. (Read 1290 times)
426HEMI
Sr. Resident
My M46 Barracuda! Member Since:October 01, 2005
on:
January 01, 2008 - 08:02:25 PM »
Just wondering how many have switched to 4 wheel disk brakes on your e-body. What are some of the problems and which is the best system to use?
Logged
Got a pretty good start on my M46 optioned Barracuda restoration but now it is on hold till I can gather more funds. Still need a few parts for it. SIU Graduate 75 AAS Automotive Tech, 94 BS Advanced Tech Studies, 1997 MSED Workforce Education and Development
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Chryco Psycho
Administrator
C-C.com Guru
Re: Brake upgrades from drum to 4 wheel disk.
Reply #1 on:
January 01, 2008 - 08:40:44 PM »
The SSBC system is a good fit but they lower priced system will interfere with the rear sway bar , Willwood are more com-plicated to install & do not even seem like an upgrade from factory front discs if you have them
Logged
426HEMI
Sr. Resident
Reply #2 on:
January 01, 2008 - 08:45:53 PM »
My current car has 4 wheel drum. Who sells the SSBC system? The complicated part does not bother me I have been in the automotive business for over 30 years and I have been ASE certified master since 1975. Gordon
Logged
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
January 01, 2008 - 10:32:26 PM »
SSBC is Stainless Steel Brake Co
www.ssbrakes.com
the Willwood seem to be a lighter system which is good for racing but not street
Bear just repackages Australian made parts
I haven`t used Master Power
Logged
bob dog
Jr. Member
Reply #4 on:
January 02, 2008 - 11:47:58 PM »
i am just finishing master power manual 4 disc they were a pain in the ass the fronts no problem the rears needed a lot of work just dont seem to be very well thought out i had 1 axle had to replace put brakes on to find it was bent slightly never new it with drum breaks installed rear caliper brackets the bolts were so close to the roter for comfort for me called tech they called back 3 days latter they said grind the head on bolts the bolts hold everything together did not do that took roters to machine shop to have inside cut down now they clear ok the first axle i had the new bearings on so i was out bearings now then find out i need 3in studs to bolt rims on take it apart to have studs pressed in E brake cables they include dont no what they fit made stock cables work need to bleed brakes hope they dont fly apart
Logged
backtobasics
Jr. Member
Reply #5 on:
January 03, 2008 - 01:09:19 PM »
I am going to throw out
www.scarebird.com
They sell the brackets, that allow the components(Rotors, Calipers, Hoses) to be bought locally (parts store stuff), and you can convert to 4wd for about 600-700 bucks, ALL 4 CORNERS. They tell you the components you need, and the bonus is it is all available at the local parts store.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
January 03, 2008 - 01:18:01 PM »
Scarebird is a great way to do it
Logged
426HEMI
Sr. Resident
Reply #7 on:
January 03, 2008 - 07:22:47 PM »
Quote from: Chryco Psycho on January 03, 2008 - 01:18:01 PM
That looks like it might work pretty good. Still thinking and considering what system to use. I would like to have a power system on it also so that might be a consideration.
Logged
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
