Author Topic: Need info on TRW L2293 383 Pistons  (Read 6589 times)
Offline hemiken
« on: January 01, 2008 - 09:43:00 PM »
Hi Guys, :clapping:
Tying to find out information about these pistons.
What compression they are and if they are a forged or cast piston ?
Kenny. :2thumbs:
Re: Need info on TRW L2293 383 Pistons
« Reply #1 on: January 01, 2008 - 10:27:41 PM »
L2293F are forged & are advertised as 11:1 comp pistons with 88cc heads & composition gasket
Offline hemiken
« Reply #2 on: January 02, 2008 - 01:30:22 AM »
 :clapping: Thanks C/P.......... I knew you would come through.........again. :2thumbs:
Offline hemiken
« Reply #3 on: January 03, 2008 - 03:19:57 AM »
Hi C/P,
My brother is looking to put a 383 together with these pistons and was thinking of using the newer Mopar Purple 509 smooth idle cam and six pack set up.  Would this cam be alright with a six pack or not ?  Car is an Australian A-body Hardtop.
Kenny.
« Reply #4 on: January 03, 2008 - 03:23:52 AM »
the .509 would be very close to the last choice I would use , the 6 pack is difficult to make work well with very low vacuum & the 509 make very low vacuum , I would lean towards  an Engle K58 or a Lunati Voodoo grind he will be far happier ijn the long run , what is the rest of the combo ,. gears intake converter stall , what is he using the car for primarily , what RPM power band does he need ? I might change my cam choice based on these
Offline hemiken
« Reply #5 on: January 03, 2008 - 03:33:19 AM »
Hey C/P,
He likes the idea of running the purple shaft cams, i was trying to tell him that if it had to be a purple shaft he should look at the 474 cam.
What are the profiles of the camshafts you recomended please.
Diff is 8 3/4 with 3:23 but changing to 3:7
Intake is the standard Edelbrock 383 six pack intake
Stall will depend on camshaft
Car will be used as a weekend car for car events and a bit of track.
Thanks,
Kenny.
« Reply #6 on: January 03, 2008 - 01:07:10 PM »
If I was using a Mopar Purple shaft I would use a .528 soild with 1.6 rockers
I still think the Engle K58 is a good choice for a hydraulic cam or a similar Lunati Voodoo
