Author Topic: Magic weapon (tool)  (Read 1059 times)
Offline Chlngrcrzy
Magic weapon (tool)
« on: January 03, 2008 - 07:54:13 PM »
Anybody have a special tool, grinder, etc. they use for grinding welds in real tight areas? My 4.5" grinder is great, but a little large and awkward for finishing things up. I am having to do a lot of rust repair around the drip rail/ rain gutter above doors, and there is only about 5/8 of an inch in there, and pretty tough to get the angle cleaned up. :clueless:
Offline 70challengerrt
Re: Magic weapon (tool)
« Reply #1 on: January 03, 2008 - 07:57:10 PM »
It's a great delima I run it too. I use a dremmel tool with a grinding tip in tight areas. Similar to the ones you use to port and polish heads, but it is slow going.
« Reply #2 on: January 03, 2008 - 08:02:33 PM »
I have a few I use on welds.
« Reply #3 on: January 03, 2008 - 08:06:52 PM »
Then theres this one
Offline 71bigblock
    • Steve's Mopars
« Reply #4 on: January 03, 2008 - 08:37:48 PM »
That one looks downright nasty.  Where can I get it or what is it called?
« Reply #5 on: January 03, 2008 - 09:26:12 PM »
I picked that one up at Carlisle last year at one of the stands. Sorry I don't have a lead for you on it. It works really good though. It never seems to wear out.
Offline hemiken
« Reply #6 on: January 03, 2008 - 09:27:42 PM »
Here in Australia those pieces are called Crabide burs for die grinders.  I use them all the time, great tool. :2thumbs:
« Last Edit: January 03, 2008 - 09:32:20 PM by hemiken »
« Reply #7 on: January 03, 2008 - 09:31:34 PM »
I saw some at my local ACE Hardware. But each ACE carries its own store format so they may or may not have em.
Offline Chlngrcrzy
« Reply #8 on: January 03, 2008 - 09:34:17 PM »
You can order carbide deburring tips through Grainger.com.  I will have to check with them to see if i can get something small enough to fit in those nasty little areas.
Offline Mt.St.BigBlock
« Reply #9 on: January 04, 2008 - 02:37:35 PM »
Hi, TP tools in OHio has them.  wwwtptools.com   search  "burrs"  Jeff
71 cuda 383 3spd manual gy9
Offline RUSTY Cuda
  • One big step foward!
« Reply #10 on: January 04, 2008 - 05:25:20 PM »
Eastwood has the burrs also, I think I got a set of 3 with different shapes.
I found a cut off tool with 2 wheels on it works great, but even when the wheels are small you cant get those corners. I know this is a NO NO but I removed the safty shield(not without my goggles on) & that got it into more spaces. the double wheels worked great on my plug welds, cuts fast & better control. I like to credit who i got the tip from but the names not comming to me, if it's one of you guys, jump in & take some credit, it works great! Rich. :2thumbs:
