Author Topic: Six Pack Kit A Good Idea Or Not?  (Read 3474 times)
Offline 73Chally
Re: Six Pack Kit A Good Idea Or Not?
« Reply #15 on: January 04, 2008 - 07:04:52 PM »
Believe it or not you can get slightly better mileage with a 6 pack, but we don't play by reality, do we?  If you think about it, if you're just cruising along, you're only running on the center carb, with is 350CFM, so until you punch it, you're doing pretty well.  The outboard carb will still trickle fuel, but not much.  Of course, who gets a 6 pack for the mileage?  :bigsmile:
Offline 426HEMI
« Reply #16 on: January 04, 2008 - 07:13:20 PM »
When I really wanted fuel mileage I unhooked the front and back carbs so I was not tempted on kicking it in.  Just something I did and it really was not that hard to do on a small block setup.  When I had the 440-6 I was not worried about fuel mileage so I could always access the power.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline pink panther
« Reply #17 on: January 04, 2008 - 08:53:16 PM »
if your not going to drive the car much, than milage shouldn't be an issue. I have never driven a hemi, but just going to shows and cruises, the people are always fascinated by the color and then they see the 6 pack and it just makes them always bend down and look at all the carbs under that big old air cleaner.  I like the 6 pack and the way it runs, I do have a healthy lump to my cam as well and the car still performs really good when you lay into it.
Offline dodge freak 2
« Reply #18 on: January 05, 2008 - 12:15:37 AM »
I am wondering if a 6 pack could help my mileage.
I love driving my car, when gas was $1.50 a gallon, I put 100 miles a day on it--high speeds means you rack the mileage up quick.
Now I put $20 in it and its gone before the days done, it stinks. Going to try a RPM intake have a S D--its a small block but this 9-10 mpg bit is killing my spending cash. 2-3 more MPG would be 20%-30% better.
Offline cudabob496
« Reply #19 on: January 05, 2008 - 02:21:02 AM »
You can make more power with a 4 barrel.
2011 Kawasaki Z1000
« Reply #20 on: January 05, 2008 - 03:26:23 AM »
6 packs will get decent milage tuned properly
Offline Samuelson1022
« Reply #21 on: January 05, 2008 - 03:33:19 AM »
I love the look of the six pack and I waited around on Ebag till i finally found one for cheap.  I haven't hooked it up yet and it probably doesn't work knowing my luck, but the guy said it was rebuilt and it looked clean.  It is painted the wrong color right now but no biggie.  I got this for a 1000 even.
Offline 73Chally
« Reply #22 on: January 05, 2008 - 09:12:52 AM »
With modifications, yes, but I believe we are talking pretty much stock.
Offline 73 challenger 440
« Reply #23 on: January 08, 2008 - 05:11:52 PM »
I am getting the 6 pak next month along with some other goodies.. I have 2x4bls on it now, the cam is pretty lumpy with a 2500 stall.. not sure on the compression and size cam.. but it boots with the setup I have now.. I really want the 6 pack on there, I dont mind if I loose some power..  I am going to run it down the track a few times with this setup, then do the same with the 6 pack to see what the time difference is.. I am going with the complete kit I seen at some web sites, but nothing mentions about kickdown linkage, I am wondering if I can just use the existing one I have...
Offline 74 340 4speed
« Reply #24 on: January 08, 2008 - 05:35:05 PM »
Six packs look awesome, but if your car is running perfectly with the 4 barrel and dual plane intake, why change it? Some motors you could probably take the carbs out of the box, and bolt them on it, and it would be almost perfect.  Since you have an aftermarket cam, they will probably be more difficult to set up.  I haven't had any experience with these setups but have played around with single four barrel setups for a while.  They are hard to beat, and not that hard to tune.  As a side note, my dad drove an almost new 69 1/2 Road Runner with the 440 Six Pac set up, 4 speed, and the dana track pack and he said that it absolutely drank gas.  He said that when he went WOT, he could see the gas hand moving towards E :lol:
Andy
1969 C/10  350|Turbo 350
1972Nova: 350|Turbo 350
Offline 426HEMI
« Reply #25 on: January 08, 2008 - 06:19:28 PM »
 :iagree:  With the 440-6 that I had you could watch it move the wrong direction.  On the small block 6 pack that I had it did not drink as much gas.  I loved both setups.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #26 on: January 08, 2008 - 06:21:42 PM »
here is what I am running now.. they are edelbrock 600's
Offline 426HEMI
« Reply #27 on: January 08, 2008 - 06:35:01 PM »
To me the 2 4's look good but the 6 pack looks great!!!!!!!  I would go for the 6 pack!!!!
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #28 on: January 09, 2008 - 02:35:17 AM »
even though I am no fan of Eddy carbs I bet it will beat the 6 pack
Offline Robb
« Reply #29 on: January 10, 2008 - 12:06:06 AM »
I saved big bucks by shopping the parts separately.   Mancini, Mancinotti (sp?), Atlantic Speed and Summit.
