Hey guys!
Got another question for you guys.
I got the tach mounted up and I got the green wire and the black wire run.
The green is the connection to the coil. The black is for ground.
Just can't figure out where the red and white wire go.
The red wire is supposed to go to a harness wire which is energized with battery voltage only when the ignition key is in the ON (RUN) position.
The white wire is supposed to go to the instrument panel lighting circuit or any lead that is controlled by the instrument panel dimmer control.
Just don't know where these two wires are supposed to go.
The tach is a sunpro super tach II.
I can't figure out the ON wire because the car doesn't run yet.
Please help me, I kinda want to get this done by tommorrow.
