Author Topic: Power Steering..Tightening the slop  (Read 1124 times)
Offline DAYLEY/CHALLENGER
« on: January 06, 2008 - 09:55:19 AM »
Hey guys....I am used to tightening the steering on manual steer by ..loosen the lock nut and turn the center screw with the screwdriver and resnug the nut.   How is this accomplished with power steering?  My steering feels like it needs a little something....Thanks, David :clueless:
Dave or David
Offline ShelbyDogg
Re: Power Steering..Tightening the slop
« Reply #1 on: January 06, 2008 - 10:15:43 AM »
Adjusted the same way, but as I'm turning the screw, I use my hand to turn the steering coupler back and forth, after pointing the wheels straight ahead. If you go too far the steering sometimes doesn't return to center while driving.  I got a rebuilt box at AutoZone for about $125 years ago.  They also carry a lifetime guarantee to replace it or refund it.
Offline 426HEMI
« Reply #2 on: January 06, 2008 - 10:17:21 AM »
 :iagree:  Just make sure it is straight ahead and then adjust.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #3 on: January 10, 2008 - 12:04:50 AM »
David, first make sure that your box is tight.  I was going through the same thing.  I swapped a firm feel box from a 78 cop car and was having some slop and thought I needed to rebuild the rag joint (you might check that too, its cheap).  It turned out that the bolts holding the box to the frame weren't torqued enough and was allowing it to wiggle just a little when I turned the wheel.
Go ahead and tighten the allen headed set screw some with the engine off.  You will know when you've gone too far, then back off until it turns smooth.  Definately don't leave it too tight if you go to far for any length of time though, it will cause severe internal wear.
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
« Reply #4 on: January 10, 2008 - 02:07:03 AM »
