Author Topic: 8 3/4 Strength  (Read 4000 times)
nivvy
8 3/4 Strength
« on: January 06, 2008 - 09:08:00 PM »
How much HP is a 8 3/4 good for ???
Offline Oldschool
  • Member Since 9-05-06
Re: 8 3/4 Strength
« Reply #1 on: January 06, 2008 - 09:51:56 PM »
It's not so much how much power will it handle, as much as it is HOW you apply it.  The heavier the car, slicks, or manual tranny sidestepping the clutch.  That combo will kill it pretty quick.  If you have a medium weight car with an auto and just a little wheelspin, it will be almost indestructable.  An auto applies the power relatively slow compared to a manual.  Bottom line, the less "shock" you give the rearend, the longer it will last...    :2cents:    :cooldancing:
Ken  --  In Georgia
Offline 426HEMI
Re: 8 3/4 Strength
« Reply #2 on: January 06, 2008 - 09:55:26 PM »
 :iagree:   :2cents:  I had one in my 440-6 and it was just fine and it was not stock.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
nivvy
Re: 8 3/4 Strength
« Reply #3 on: January 06, 2008 - 10:19:34 PM »
well you guys know what i have 650+hp ... 727 ... thinking of throwing a 200 shot at it ??? really ow affetiv i bracing ??? im thinking of going dana 60..
Offline CrazyPete
Re: 8 3/4 Strength
« Reply #4 on: January 07, 2008 - 07:56:47 AM »
mine has broken several times usually the pinion was the problem anything from twisted splines to totally snapping the pinion off.  But i know several guys running alot more hp than i did that have never had issues.  All i can tell you is NEVER buy ZOOM gears there junk.
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Offline Oldschool
Re: 8 3/4 Strength
« Reply #5 on: January 07, 2008 - 08:16:51 AM »
I would recommend Moser, Richmond Gear, or Strange Engineering for rear gear stuff...    :2thumbs:
Ken  --  In Georgia
Offline ShelbyDogg
Re: 8 3/4 Strength
« Reply #6 on: January 07, 2008 - 11:49:15 AM »
My race car with 500 hp (not much) and slicks on a sticky staring line tore those gears up.  Rips them right off of the ring or pinion.  My car was only 2300 lbs. Put a DANA in it and ran for 8 more years till I sold it.
 In my opinion, you need a DANA. Stroker, you are right on the verge of blowing up that puny 8-3/4.    They will only hold up till you get some serious traction, them BOOOOM!
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: 8 3/4 Strength
« Reply #7 on: January 07, 2008 - 12:29:50 PM »
With that much power, I would consider a Dana.  I have an 8 3/4 in the Dart I use to race and it handled a 440 (about 450hp) with an auto and using the footbrake only.  I would not risk another 200 shot without a larger rear.
Re: 8 3/4 Strength
« Reply #8 on: January 07, 2008 - 12:31:48 PM »
If you have to spend $$ to fix the diff I would starts spending $$ on the dana
Offline Carlwalski
Re: 8 3/4 Strength
« Reply #9 on: January 07, 2008 - 02:30:07 PM »
Go for the Dana if not for the added strength then the peace of mind. Two words: Dr Diff. :2thumbs:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
nivvy
Re: 8 3/4 Strength
« Reply #10 on: January 07, 2008 - 03:49:49 PM »
how much does the brace really help???
Offline ShelbyDogg
Re: 8 3/4 Strength
« Reply #11 on: January 07, 2008 - 05:06:02 PM »
The brace will only help if you're trying to twist the center section out from between the axle tubes. The ring gear will break befroe that happens on an 8-3/4.  It isn't needed in a Dana at all. The most I added to my DANA was steel caps. I ran a tranny brake and held it to 4000 Rpm while the lights came down. I never hurt it at all.  I was running 16.5-33" slicks too.
Offline 426HEMI
Re: 8 3/4 Strength
« Reply #12 on: January 07, 2008 - 06:17:38 PM »
I would love that setup.  It would be really cool to have.  How Much?
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Re: 8 3/4 Strength
« Reply #13 on: January 07, 2008 - 06:39:50 PM »
I'm guessing you don't want to know.   :smilielol:
Offline Carlwalski
Re: 8 3/4 Strength
« Reply #14 on: January 07, 2008 - 07:57:03 PM »
I don't want to know either. :lol:
Don't really like to speak prices but I consider it a competitive price. You pay for what you get.  ;)
If you're really keen and would like one check out Dr-Diff's website: http://members.aol.com/doctordiff/dana.html
:cheers:
