Author Topic: Splash guards?  (Read 878 times)
Offline Katfish
  • 70 Challenger
Splash guards?
« on: January 06, 2008 - 10:43:43 PM »
Not sure if this is the right name.  It's the plastic part that bolts to the frame rails on the front end (front of passenger tire).
Any 70-74 E-body will work.  The pic is the part needed.
Thx
« Last Edit: January 08, 2008 - 11:48:19 PM by Katfish »
« Last Edit: January 07, 2008 - 08:45:57 AM by bullitt99 »
Offline Katfish
  • 70 Challenger
Re: Splash guards?
« Reply #2 on: January 07, 2008 - 05:25:55 PM »
The starter shield is the only 1 that looks familiar.  I need the passenger side, these are bolted to the frame.  The 1st ebay auction pic looks different and is riveted.
I'll try to post  a pic.
Offline 73EStroker
Re: Splash guards?
« Reply #3 on: January 07, 2008 - 08:55:29 PM »
Hey Katfish - bullitt is correct. You need the little rubber flappy one for the rear of the passenger side and the one in the picture you posted for the front right. I was getting the rubber ones yesterday from a local (in Calgary) Mopar dismantler. I still need the front right but will just buy a repro. Gotta get this thing going soon!!!! Also I learnt that the B body 71-72 rubber flappy things are the same as well.
Barry (Salmon Arm)
Offline Katfish
  • 70 Challenger
Re: Splash guards?
« Reply #4 on: January 08, 2008 - 09:48:39 PM »
Boy, I'm really confused.  Aren't the rubber pieces removeable when adjusting the upper control arms.  There are 2 of these on each side right near the UCA bolts?  These are mounted to the fenderwalls.
I need the hard molded plastic pieces that bolt to the frame rails and hand down toward the ground.
Re: Splash guards?
« Reply #5 on: January 08, 2008 - 09:55:09 PM »
Only one side hangs down, on the drivers side is the starter shield nothing on the passenger side...correct about the rubber pieces.
Offline Katfish
  • 70 Challenger
Re: Splash guards?
« Reply #6 on: January 08, 2008 - 11:49:25 PM »
Thanks for clearing that up, anyone have the hard plastic part for the passenger side?
Thx
