Author Topic: rallye hood  (Read 3430 times)
sleepychallenger
rallye hood
« on: January 07, 2008 - 07:25:47 AM »
for the challenger rallye hood, is it suppoesed to have a slight crease in the front of the hood. i have seen some pics where it does have it right on the top of the hood about 4 inches long in the center in the front. i want to make sure that if it is suppoesed to be there i do not have it covered up.
sleepychallenger
Re: rallye hood
« Reply #1 on: January 07, 2008 - 07:30:48 AM »
also wanted to get your opinion, should i do hood pins or leave them out????  :feedback:
Offline Black340
  • 1973 challenger 340 4 Speed
Re: rallye hood
« Reply #2 on: January 07, 2008 - 12:06:28 PM »
MPO leave them out
hope the pic help
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: rallye hood
« Reply #3 on: January 07, 2008 - 12:54:18 PM »
I would leave them off, but it is your car.
A good reason to put them on would be to remove the latch attached to the hood and just use the hood pins.  I have seen this on another Challenger and it worked well.  Just a thought.   :2thumbs:
Re: rallye hood
« Reply #4 on: January 07, 2008 - 01:18:25 PM »
Catch your skull on the hood retainer a few times and this starts to sound like a real good idea.
sleepychallenger
Re: rallye hood
« Reply #5 on: January 07, 2008 - 01:47:24 PM »
have caught my head many times, but would still use the pins and the latch
Offline LAA66
Re: rallye hood
« Reply #6 on: January 07, 2008 - 01:55:27 PM »
 I thought about installing pins but wondered if over time the cables might rub the trim or finish off. Also chips from one getting away from you when unpinning them. :clueless:
sleepychallenger
Re: rallye hood
« Reply #7 on: January 07, 2008 - 02:20:25 PM »
i think that the cables have a plastic coating on them that makes it so it doesnt hurt the chrome
Re: rallye hood
« Reply #8 on: January 07, 2008 - 05:51:41 PM »
That is an EXCELLENT point.  :thumbsup:
 Since I installed them, I can tell you to steer the cables into the crack between the hood and fenders... otherwise it will rub a spot on your paint even though the cable is plastic coated. Unpinning them is not a problem.
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: rallye hood
« Reply #9 on: January 07, 2008 - 06:04:34 PM »
B/E body pin kits have 23 inch lanyards. I have had them on mine since the build 7 years ago and have had no rub issues at all.  i did remove the safety catch or head banger but left the latch in.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Re: rallye hood
« Reply #10 on: January 07, 2008 - 06:09:07 PM »
Challenger lanyards are only 18" long, so I guess you have lanyards from a Cuda? They are longer.
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: rallye hood
« Reply #11 on: January 08, 2008 - 11:09:51 AM »
yes 70-71 had 18", 23" fit alot better not as tight and wont rub
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Re: rallye hood
« Reply #12 on: January 08, 2008 - 05:49:50 PM »
Gotcha.  :thumbsup:
Offline miketyler
    • www.miketyler.net
Re: rallye hood
« Reply #13 on: January 11, 2008 - 07:12:01 PM »
That or go without lanyards all together, just use snug fitting pins   :ylsuper:
« Last Edit: January 11, 2008 - 07:18:42 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline LAA66
Re: rallye hood
« Reply #14 on: January 11, 2008 - 08:36:43 PM »
 It's all about the look really. The whole package.
 Kinda like, what's pinned down under the hood.
