Author Topic: uneven ride height with S.S. springs ????  (Read 881 times)
Offline MJB
« on: January 07, 2008 - 05:03:07 PM »
I recently installed super stock springs on my '70 CUDA.  Obviously the right spring is stiffer with more leaves to resist the body torsion off the line.  This sounds great when I'm launching but now the right side of the car is about 1/2" higher than the left all the time.   Is this normal with S.S. springs or do I have another problem??   I am considering putting a 1/2" lowering block on the right side to compensate.   Has anyone else had this problem?  Any feedback would be appreciated.
Thanks-
Offline 73Chally
Re: uneven ride height with S.S. springs ????
« Reply #1 on: January 07, 2008 - 05:48:26 PM »
I believe that is normal for the SS springs, but not 100% sure.
Offline ShelbyDogg
« Reply #2 on: January 07, 2008 - 05:52:28 PM »
Common problem.
The solution in the early 70s was too crank up the driver's side torsion bar to lift the left side a little bit.
« Reply #3 on: January 07, 2008 - 05:56:24 PM »
Common problem.
« Reply #4 on: January 08, 2008 - 02:23:33 AM »
most cars do not exactly level with SS springs , the cure as suggested above is to crank the opposite T bar
Offline Oldschool
  • Member Since 9-05-06
« Reply #5 on: January 08, 2008 - 12:13:58 PM »
After cranking the t-bar up, don't forget to have the front end alignment re-checked...    :2thumbs:
Ken  --  In Georgia
Offline MJB
« Reply #6 on: January 09, 2008 - 09:55:37 AM »
Thanks for that info guys.  I will try that approach before considering the lowering block.
