Author Topic: Need help decoding trans  (Read 991 times)
Offline VitaminCuda
« on: January 07, 2008 - 05:32:18 PM »
I have a  transmission with C-99539 E / C 99129 H  and one that has C-99539 E  / C 99129 L. They came out of '70 Cudas, but I don't if they're correct. The 1st one has a (vin?) stamp that looks like 8354329. Any help is appreciated
Re: Need help decoding trans
« Reply #1 on: January 08, 2008 - 02:34:12 AM »
the casting # give you no info at all just that they are 833 trannys
 the stamping on the Pad has all the info  , likely you have the serial #  B354329 stamped there , there should be a second series of #s with build date & gear ratio info above the serial # you listed , the serial # should match the dash Vin
Offline VitaminCuda
« Reply #2 on: January 08, 2008 - 10:52:38 AM »
Looks like 1 has 3P37324  the other looks like 4337-21 :dunno:
