Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Six Pack intake gaskets?
« previous
next »
Print
Pages: [
1
Author
Topic: Six Pack intake gaskets? (Read 1112 times)
AMXguy
Sr. Member
on:
January 08, 2008 - 01:48:42 PM »
I found where you should put a set of fiber gaskets on both sides of the valley pan gasket, is this right? there is a set of mopar performance gaskets sold for this purpose are they the best way to go or is there better ones out there?
Logged
1970 R/T SE Challenger
1970 Superbee
1969 S code Mach 1
1967 GTO
Chryco Psycho
Administrator
C-C.com Guru
Re: Six Pack intake gaskets?
Reply #1 on:
January 09, 2008 - 02:33:52 AM »
Order the Fel Pro 1215 [440], & use the gaskets between the pan & heads , I leave out the upper gasket , it makes it too hard to get the intake back on
Logged
AMXguy
Sr. Member
Reply #2 on:
January 09, 2008 - 10:40:10 AM »
OK, My engine is painted up show quality and in the car so do I dare just put the gaskets between the pan and head without replacing the pan with a new one? I hate to replace it if I don't have to but I don't want a vac leak either.
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
January 09, 2008 - 11:28:05 AM »
you should be fine But I would paint th new pan & install it as it aslo blocks the heat crossover port which is a big advantage
Logged
AMXguy
Sr. Member
Reply #4 on:
January 09, 2008 - 11:39:25 AM »
I have the block off pan in it now, I use Permatex for this kind of stuff most of the time, is that the best thing to use on an intake or is there a better route?
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
scrag
Jr. Member
Reply #5 on:
January 09, 2008 - 04:18:37 PM »
I found that using the gasket set (one on eitherside of the intake portion of the valley pan) cause a mismatch between the intake and the the head. I have a number of problems trying to get a good fit. You will also find that the bolt holes likely will not line up - and require the intake holes to be opened up to allow you to get the bolts in. What was recommended to me and what I am going to do when I reassemble in a week is to use the valley pan only, use the Grey RTV (Permatex) - also HONDABOND is also recommended - on the ends and top and bottom of the pan forming a bead to ensure a good seal - let it set up for a day prior to running the motor.
Logged
Robb
Sr. Member
Reply #6 on:
January 10, 2008 - 12:03:40 AM »
using both paper gasket sets is a challenge to get the intake back on but it can be done. Just an extra beer and a little more swearing.
Ive been using the purple paint-on gasket stuff by permatex in between the heads and pan and gaskets and intake. Stays tacky.
BTDT
Logged
70 Challenger SE (
440 SIX PACK
/ Keisler 5 speed, R/T SE replication) 68 Sport Satellite Convertible 383 Super Commando / 727 Survivor
2002 Trans AM WS6 convertible: DD
1999 4Runner 4x4: lifted-locked-armored expedition vehicle
1990 Jeep XJ 4x4: Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb Rock Crawler
Chryco Psycho
Administrator
C-C.com Guru
Reply #7 on:
January 10, 2008 - 02:27:13 AM »
I rarely havce a problem with 1 set of the paper gaskets , Felpor does sell the side gaskets separatly from the intake pan but I do not have th e# handy
you can start 2 bolts on 1 side & pry the intake down with the heat riser clearance hole
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
