Author Topic: Interior lights color?  (Read 1522 times)
Offline Scatterbrain
  • 1973 Challenger
« on: January 08, 2008 - 06:49:08 PM »
Yesterday was the first time driving my car in the dark.  A friend blew out the clutch on his RX8 and asked for some help getting home from the shop.  On the drive home in the dark I noticed a soft eerie blue glow from the dash.  I fiddled with the dimmer switch and found that I had dash lights.  I managed to get them bright enough to see the gauges... barely.  Are they supposed to be blue?  Any way to get them brighter?  Obviously, the switch is a little faulty, but even if I replace it how bright can I expect the lights to be?
Re: Interior lights color?
« Reply #1 on: January 08, 2008 - 07:02:14 PM »
They should be greenish in color. Being slightly dim is common.  :eek4: You are normal.
My dimmer switch went to heaven, so I replaced it with a toggle switch. It looks SO much brighter now.  :grinyes: Why would you want to dim something that is already dim?  :lol:
  • 1973 Challenger
« Reply #2 on: January 08, 2008 - 07:03:58 PM »
Green huh.  My favorite color, but mine is definitely blue.
« Reply #3 on: January 08, 2008 - 07:07:48 PM »
Someone else mentioned that too. He had a 73. Maybe they changed it in the later years?  :dunno:
« Reply #4 on: January 08, 2008 - 07:19:16 PM »
My rally dash is green but some are blue, the one I saw was a '74 w/ standard dash... When working correctly I think the brightness is adequate but the condition of your panel dimmer may be the real issue, as far as replacing that good luck as they are scarce & very pricey.  Try cleaning the contacts of the dimmer you have.
Offline dawgs 73
« Reply #5 on: January 08, 2008 - 11:22:25 PM »
My '73 Cuda has blue light filters and they look original. Can't say they are absolutely original, but the filters look like they've been there forever. And they are dim...................
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #6 on: January 09, 2008 - 12:16:16 AM »
bypass the panel dimmer
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #7 on: January 09, 2008 - 01:44:39 AM »
My '73 Cuda has  :grinyes: green  :grinyes: dash lights....100% original from the Hamtramck Assembly Plant.  Mine have never been replaced or modified.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #8 on: January 09, 2008 - 04:11:05 AM »
I got green dims, but would love to trade it for a blue ligth, blue is my favorite color...  :bigsmile:
Offline hooD
  • detroit iron
« Reply #9 on: January 15, 2008 - 03:00:06 AM »
I was just thinking about the color Blue.  Green and Yellow make Blue.  Green lights plus lots of cigarette smoke (Yellow) makes Blue!   Clean them nicotine covered light bulbs and I bet they'll shine Green again!  :roflsmiley:
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« Reply #10 on: January 18, 2008 - 05:08:36 AM »
They might be dim because of corrosion in the connectors going to the dash lamps. Try tracing the wires to the lamps and clean any connections.
If the headlights are dim, too, it's possible your alternator or regulator isn't working right and there isn't enough voltage in your system. I'd put a test voltmeter on and see what's up.
Offline FJ5_440
  • Wisconsin
« Reply #11 on: January 18, 2008 - 07:11:33 AM »
Actually blue and yellow make green, maybe his are clean! ;D
Seriously, I have seen both blue and green filters on the dash lights, but many more green than blue.
** Shane **
Offline miketyler
    • www.miketyler.net
« Reply #12 on: January 29, 2008 - 07:26:32 AM »
is there a way to bypass the dimmer without an additional toggle switch? I would just like them to come on nice and bright when I switch my park lights on
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
