Author Topic: Original Muffler...Challenger  (Read 1380 times)
Offline DAYLEY/CHALLENGER
« on: January 08, 2008 - 07:41:04 PM »
I removed the original mufflers from my Car when I got it. Would you believe they were still on it???  They were sort of blown out...............!! For some reason I didn't measure the body length and tip to tip length.   Anyone out there have those measurements.  I am not going back to original but need the measurements in order not to have the tips sticking out too far or not far enough.   Thanks, David
Dave or David
Re: Original Muffler...Challenger
« Reply #1 on: January 08, 2008 - 08:11:55 PM »
David, I can get you the exact #s in a few minutes... did you see the 20% off Year one code?New code is JAN8 and is good through 01-16-08"
  They carry replacements for $132 ea so price wise you could not beat them, with the discount by more than $30 or so each using generic undersized items...I suppose your referring to the big 7" round mufflers by the gas tank. The economy way is to put oval mufflers forward of the axle & just use tail pipes to the rear.
Wade
« Last Edit: January 08, 2008 - 08:19:16 PM by bullitt99 »
« Reply #2 on: January 08, 2008 - 08:13:46 PM »
Case length 21" diameter 7"  see diagram for offset      "New code is JAN8 and is good through 01-16-08"
« Last Edit: January 08, 2008 - 08:18:28 PM by bullitt99 »
« Reply #3 on: January 08, 2008 - 08:22:29 PM »
Thanks Wade.   And yes I am thinking of the economy way............Just want to sound good.
Dave or David
« Reply #4 on: January 08, 2008 - 08:43:57 PM »
a good thread to read...I'll get some #s of the OE resonators for you.
http://www.cuda-challenger.com/cc/index.php?topic=23530.0
« Reply #5 on: January 08, 2008 - 08:58:36 PM »
OE resonator dimensions 7.5" wide 3.5" high 12" long Inlet & Outlet centered & based on what I have read 2.5" diameter
Offline Robb
« Reply #6 on: February 01, 2008 - 05:53:03 PM »
Just thought I would add to this thread...
for the last 5 years I have had the TTI 2.5 inch exhaust kit on my Challenger, with the Dynomax turbo mufflers.   always had a drone at cruising rpm, and sounded good on the outside but loud on the inside.  if the ride was longer than 20 minutes, it was a guaranteed earache.
I tried putting on some glass packs behind the mufflers and they took off the idle and mellowed the rasp, but didnt do chit for the drone.
 :working:   just got done putting on the ebody 6pack Accurrate system on to replace it, and wow what a difference.   The system bolted right on (way easier than TTI), except for needing a couple of clearancing hammer hits (the driverside torsion bar and the passenger side fast ratio idler arm (which TTI needed too))  and the sound is perfect.   Finally ! :faint:
it still rumbles at idle, and it still has a noticeable performance sound at 3500+ rpm  but there is no drone at cruise or inside the car while idleing.  I can hear the engine and I can hear the radio.
maybe I lost 10 horsepower but I dont race so Ill never really notice it missing.   :swaying:
Accurate Exhaust has a sale going right now for 10% off.   :money:
the resonators are 2-1/4 diameter, as are the mufflers and the over-axle-pipes,   but on the 6pack kit, the head pipes are 2.5    There is a place that you can slip in a H pipe too, so thats on my summer Welding list of "things to weld".
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
« Reply #7 on: February 01, 2008 - 08:22:20 PM »
What I ended up with..........http://big-dog.us/challenger/videos.html
Listen to the new exhaust video..............
I used Thrush Turbo........about $20.00 each.....
Dave or David
