Author Topic: How many oil-pans for BB..???  (Read 2123 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: January 09, 2008 - 08:07:15 AM »
I need an new oilpan for my BB..
Rigth now I got a homemade, very deep one on it, so deep there is a "tunnel" rigth trough it for the centerlink,? is that what it's called.???  And that meens that I got to have the car reel high in front,  Now I want it DOWN...
How many different oilpans is out there....  What do I need for 68 A-body..???
Offline Oldschool
  • Member Since 9-05-06
Re: How many oil-pans for BB..???
« Reply #1 on: January 09, 2008 - 08:26:41 AM »
I have always had great luck running Milodon oil pans.  I am currently running one on the Beast.  It is a 7 quart setup with decent ground clearance.  My header collectors are lower than the pan.  Summit and Jeg's both sell Milodon for your application.  If not, go to Milodon's website and contact them for what you need...    :cheers:
Ken  --  In Georgia
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: January 09, 2008 - 08:56:27 AM »
Any difference in sump back / middle / front..???  Wich one...
Offline Oldschool
« Reply #3 on: January 09, 2008 - 08:59:04 AM »
I always run the ones with the center sump and have had zero issues of any kind..   :2thumbs:
Ken  --  In Georgia
« Reply #4 on: January 09, 2008 - 11:27:05 AM »
the Milodon 7 QT hangs too low ,  the wide Milodon pan will fit the crossmember but not an A body & the pan has to be installed once the engine is in place , I know Brewers has some Big block A body pans
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #5 on: January 09, 2008 - 11:32:16 AM »
If I just want a simple original BB one, - where is the sump supposed to be then...???
Swedefish
« Reply #6 on: January 09, 2008 - 01:03:36 PM »
I use the "402" pan, otherwise check this link.
http://www.440source.com/oilpans.htm
« Reply #7 on: January 10, 2008 - 02:10:25 AM »
Hemi pan Pkg from Mancini with 3/8" pick up tube with baffles , it is a center sump pan 6 qt capacity
Offline 70_challenger
  • Suburban Detroit, Michigan
« Reply #8 on: January 10, 2008 - 01:23:26 PM »
I am no A-body expert, but here is what I have found with my Challenger.
I was looking for a '402' pan to replace my current '933' pan.  That link to 440 Source shows the factory pans clearly.  Unfortunately, I have discovered that a lot of these factory pans are only 4 quart capacity!
So I am following the advice of my engine builder (and CP), and getting the Hemi pan from Mancini.
http://chucker54.stores.yahoo.net/streethemoil.html
There is a good selection of oil pans on Mancini's website.  I don't know how difficult it will be to ship to Denmark, though.
-Tom
« Last Edit: January 10, 2008 - 01:27:07 PM by 70_challenger »
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #9 on: January 10, 2008 - 01:32:46 PM »
From Mancini web:
""Center sump style is used on passenger car applications, while the rear sump style is used in pickups""
No other options, ..???   Any Center sump style will fit my 68 Cuda...???
