Author Topic: Axle codes on fender tag?  (Read 2578 times)
Offline ChallengerHK
« on: January 11, 2008 - 10:02:18 AM »
Is the axle identified on the fender tag, or only on the broadcast sheet?
- Han Solo, Star Wars
Re: Axle codes on fender tag?
« Reply #1 on: January 11, 2008 - 11:58:31 AM »
I think the fender tag only tells the rear gear ratio.
Offline 426HEMI
« Reply #2 on: January 11, 2008 - 12:13:42 PM »
I do not think that the axle information is on the fender tag.  May be in a special option only.  That info is on the build sheet and may be correct there.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #3 on: January 11, 2008 - 02:27:20 PM »
Thanks. I found a Fury III the other day and I wanted to verify the axle (or, more to the point, that the axle is or isn't worth having).  I guess I'll have to pull the rear seat to make sure.
Offline 426HEMI
« Reply #4 on: January 11, 2008 - 02:29:26 PM »
Or look on the rear axle there should be a tag on it.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline DAYTONA
« Reply #5 on: January 11, 2008 - 09:39:40 PM »
not on Ebodys....some older MOPARS have codes on the tag
« Reply #6 on: January 12, 2008 - 03:11:44 AM »
the A33 code designates 3.54 Dana , A34 is 4.10 Dana , no codes for 8 3/4
Offline ozrt4406
« Reply #7 on: January 12, 2008 - 03:21:00 AM »
SO WHAT WOULD BE THE STD RATIO FOR A 70  ???440 AUTO RT? IS THERE A STD RATIO? ???
T/A AND R/T............... IM GREEDY.
« Reply #8 on: January 12, 2008 - 04:31:17 AM »
3.23 likely , but no std ratio I know of , you could have 2.9 or 2.7 even
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #9 on: January 12, 2008 - 08:53:15 PM »
Actually, there are axle codes on the fender tag for the 8 3/4: 'A31' = 8 3/4, 3:91 posi...
Offline DAYTONA
« Reply #10 on: January 12, 2008 - 09:23:06 PM »
...I learned something here today.....out of all the ebodys I have owned I have never had one with a code...apparently they were all stock....thanx for the info...my A12 Bee has a code on the fender tag
« Reply #11 on: January 12, 2008 - 09:55:22 PM »
Can anybody tell me if there's an axle code on this tag? It was a 360-2bbl 904 car, so I doubt there's anything exciting, but you never know. I ran it through an online decoder, but one whole line came up as unidentifiable.
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #12 on: January 12, 2008 - 10:19:40 PM »
No axle code on yours.  Fender tag axle codes (A31, A33, A34) are only denoted on 'performance' ratios; i.e. the A33 code designates 3.54 Dana , A34 is 4.10 Dana (as stated by Chryco) and A31 is 3:91 8 3/4. You do have a very cool and unusual color combo: Tawny Gold ext/gold int/yellow side moulding.
« Reply #13 on: January 12, 2008 - 11:04:07 PM »
Thanks, FM3.  Not mine, just a car I saw in a salvage yard.  It did look pretty cool, though.
