Author Topic: got my am-8 track for my GC back from wards classic radio repair  (Read 10681 times)
Re: got my am-8 track for my GC back from wards classic radio repair
« Reply #15 on: January 13, 2008 - 11:48:03 PM »
Wow 385 bucks to convert my am to an upgraded am/fm  :2thumbs:  I may just do that.  Sounds like a good deal and fit right back in the original slot
Offline Street_Challenged73
« Reply #16 on: January 13, 2008 - 11:54:13 PM »
That turned out looking very nice!
Offline moparnut
    • My Photo's
« Reply #17 on: January 14, 2008 - 12:22:57 PM »
Thank all,I had considered selling it all but i am a purist and want to keep it original.Even tho i could probable get alot of $$$$ for the 8 track and dash parts.
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Yellow_Fish
« Reply #18 on: February 12, 2008 - 10:30:19 AM »
You know, that you can do an "I-pod" plug install on your factory radio for about $5 and an hr's time? In the case of all of the stock radios you remove the center wire on the volume cont and run it to a mini earphone plug with switch. Hook the old wire to the contact that will disconnect when the plug is inserted and the hot wire (headphone out) back to the center pin on the radio. You will also need a ground (second conductor on a mono plug). This will work for an AM radio but you will only get one channel. For a stereo (AM-FM) there are 2 volume pots ganged together and the operation needs to be done on both, but this will give you 2 channels (stereo). The volume will be controlled from your I-pod.
If you like the volume cont on the old stereo to work for your I-Pod input you can hook your input up to the center pins on the radio-tape switch which is on the tape head pre-amp board (a separate small ckt board that the tape head plugs into). This works really well on the old AM-8 Track. You get much better level this way also. Works great for FM too, jut plug in a FM walkman.
Just remember that on an AM you have 1 wire to switch and a common ground and on a stereo you have 2 inputs to switch and a ground. The radio's original AM, FM, or tape will work when you unplug the mini earphone plug (if you wire it correctly).
Russ
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« Reply #19 on: February 13, 2008 - 04:01:27 PM »
Quote
This is a great tip. I also think you can adapt stereo input to the one channel by simply shorting the left and right channels together, then feeding them in to the mono amp.
Yellow_Fish
« Reply #20 on: February 13, 2008 - 06:36:21 PM »
I would not do that. Use a device that has FM/FM stereo or a mono setting. You can build a ckt to combine L and R ch.
Russ
Offline BruteForce
« Reply #21 on: February 13, 2008 - 07:03:46 PM »
Here's some extensive discussion on the topic of the right way to convert stereo to mono:
http://www.macintouch.com/readerreports/audio/topic2091.html
